Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 07-19-2015, 11:11 AM   #1
'63GENIII
'63GENIII's Avatar
1973 Trac Lok Dana 60 + driveshaft from '63 k truck
I've got a 1973 Dana 60 with a Trac Lok that I pulled out of my '63. Nothing wrong with it except it does need a drivers side wheel cylinder. The reason I'm getting rid of it is that I swapped in a disc brake 14B. The spring measurements are 40.5 - standard GM. The Trac Lok works great. Parking brake cables are included, shock mounts for the '63 are still on it. I'm including the driveshaft as well. Its got the smaller joints (3310?) on it and is about 2 years old. I had it built when I swapped from the divorced T221 to the divorced 205. I needed a longer DS for the swap. 200$ takes it. Really don't want to ship it.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 12-12-2015, 06:44 AM   #2
63frankintruck
Re: 1973 Trac Lok Dana 60 + driveshaft from '63 k truck
What gear ratio? Wish you would consider shipping. I'm i. 76262 zip and my rear is shot in my 63 1/2 ton long bed. ( I think this would work in my truck?)
63frankintruck is offline   Reply With Quote
Old 12-12-2015, 09:39 AM   #3
Mathew21
Mathew21's Avatar
If you decide to separate the drive shaft and are willing to ship it I would be interested pending a measurement of it.
Thanks, Matt
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 12-12-2015, 11:01 AM   #4
'63GENIII
'63GENIII's Avatar
Sorry, the Dana sold already. Thanks for the interest
Chris
'63 k15 long step
Old 12-12-2015, 11:03 AM   #5
'63GENIII
'63GENIII's Avatar
Thanks, Matt
I'll get some measurement on the DS today. If you pm your zip, I'll check into shipping.
Chris
'63 k15 long step
