07-22-2015, 10:12 AM | #1 |
4wd Blazer to 2wd Blazer
I know this is a blazer, but I need the truck guys info.
1st question: I have a 72 blazer and I was wondering if it will fit on a 71 or 71 truck frame? 2nd question: If I keep my frame, should I keep the front diff, rear diff, 4 speed trans, transfer case all together to sell? Thanks guys
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
07-22-2015, 10:31 AM | #2 |
Member #1049
Re: 4wd Blazer to 2wd Blazer
It is not a direct swap, you will have to shorten the truck frame, change body mounts and add a few holes. For me it is less work to just covert the Blazer frame to 2WD.
I have found parting out piece by piece yields the best return |
07-22-2015, 10:32 AM | #3 |
Thanks for the info. Should I keep my rear end when I go 2WD or is it more for a 4wd set-up?
07-22-2015, 10:40 AM | #4 |
PITbut
In for this answer.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
07-22-2015, 10:48 AM | #5 |
Member #1049
It all depends on your goals. I have found the easiest and least costly is to simply relocate the 4X4 rear end to on top of the springs, off set drill the spring perch centering hole 1 inch, and install 5 lug axles shafts and drums.
Here are a couple of examples of the ride height of the 4X4 to 2WD axle flip from a couple of the Blazers I have converted |
07-22-2015, 10:56 AM | #6 | |
07-22-2015, 10:56 AM | #7 |
Where is the cheapest place you have found for getting the 5 lug axles?
07-22-2015, 10:58 AM | #8 |
Member #1049
If you decide to add blocks and go lower you will need to C notch the frame. Trailing arms will work, BUT it is a lot more work as the 4X4 frames are straight over the rear axle and the 2wd frame "bulge out" so you will have to fabricate a crossmember and coil spring mount
07-22-2015, 11:00 AM | #9 |
Member #1049
I usually purchase an entire 71/72 1/2 ton 2wd parts truck and use all the components
07-22-2015, 11:00 AM | #10 |
That is no problem. Thanks Livrat, you have been a big help.
07-22-2015, 11:37 AM | #11 |
Guys: It's a 4wd vehicle. You are going the wrong direction. Suppose to go up with 4wd vehicles, not down!
07-22-2015, 11:49 AM | #12 |
should I sell front diff, 4 speed trans, transfer case all together or separate them?
07-22-2015, 12:26 PM | #13 |
Member #1049
09-13-2023, 07:19 AM | #14 |
I wrecked my 4X4 in 2007 and almost got rid of it when I found a frame a fella had started to make into 2wd. Of course the rear trailing arms did not fit the 4x4 framd and I should have bagged it then but I was very low on funds. So I just put the original rear from my 4X in with the leaf springs. Later on I might get a custom rear setup but for now, my thinking, is that it is good enough for Camaros and most muscle cars as well as 4X4s. I'm not big on cut down frames. I know this will spark the great debate. Sorry. Aint gonna do it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
