Old 07-27-2015, 08:03 AM   #1
J Shepardson
03 blazer 4.3 fuel pressure
Hi guys, I just ran a fuel pressure test/leak down and was hoping I could get some thoughts on my readings.
This is what I got:
Key on @ 58 psi, after the key is on for 3 seconds it drops down to 53 and remains constent, no further drop
Idle @ 50
reving the engine @ 48~58
holding the throttle at 2k (the max it will go) @ 58
Then engine off @ 46 (will hold without loss)
These numbers seem kinda low to me, any thoughts?
Thank you
(This is a repost, believe I originally posted this in the wrong sub forum)
J Shepardson is offline   Reply With Quote
Old 07-27-2015, 08:35 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: 03 blazer 4.3 fuel pressure
Keeping in mind we may have variation in gauge calibration I see no cause for concern. Is there a certain problem you're going after?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 07-27-2015, 11:21 AM   #3
J Shepardson
She's been spitting, sputtering and stuttering. I've had her for 5 years and there has always been an idle miss, recently it's been getting worse, now she's really carrying on when driving. I just started getting a solid ses light which is now blinking, it's coming up as a random misfire. I've changed the plugs, cap, rotor, fixed the vacuum leaks and checked the maf. Nothing seems to be making a difference. She seems to run fine cold, but after she gets up to temperature she throws a tantrum. Other than testing the fuel and knock sensor (which I haven't done yet) I'm at a loss.
Old 07-29-2015, 11:11 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
It may be time to take it to a shop
Old 07-29-2015, 12:07 PM   #5
ironroad9c1
Master Hater
these things are bad for chewing up dist gears and just dist in general going bad I got a metal replacement from skip white on ebay for my ex wifes 2002 ZR2
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 07-30-2015, 08:23 PM   #6
J Shepardson
I'll double check that distributor for play this weekend
