Old 07-27-2015, 05:54 PM   #1
zicc1835
zicc1835's Avatar
short or long water pump
i know this has been asked a mil times..... i have a 72 402 alternator is on the drivers side it had factory air ..... is it a short pump ? looks like it measures the same as my 67 original 327 from the block to where the fan bolts on
thanks
jz
zicc1835 is offline   Reply With Quote
Old 07-27-2015, 11:10 PM   #2
Captainfab
60-66 Nut
Re: short or long water pump
With the alternator on the drivers side, it should be a short water pump.
thanks
jz
Old 07-28-2015, 03:49 AM   #3
zicc1835
zicc1835's Avatar
Thank u
Old 07-28-2015, 10:53 AM   #4
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
My '69 396 has the alt on the driver's side and a vintage air compressor on the passenger side. The water pump is a long shaft and the bracketry is an Alan Grove Setup. When I got my truck the engine and brackets were disassembled and in milk crates and zip lock baggies. Thank goodness I am good at jigsaw puzzles.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 07-28-2015, 08:54 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
ALL trucks with V-8's from 1967 to 1972 had short water pumps from the factory.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-28-2015, 11:16 PM   #6
Captainfab
60-66 Nut
Actually from '55-'72 if ya wanna get technical
Gary
