Old 07-28-2015, 08:07 AM   #1
11555wally
Question On Tilt Steering Column
I would like some help on a tilt wheel steering column I just bought. Attached are pics of the column where I think the neutral safety/back up light switch goes. I was wondering how the switch attaches. Some pics I see show what I have and others show the switch being held on by a couple of screws. Am I missing something. I can't look at my existing column because it is in the body shop right now. My truck is a 86 C10 and this column is supposedly off from an 86. Want to make sure what I have will work be for I send the column for rebuilding. Thanks as always
11555wally is offline   Reply With Quote
Old 07-28-2015, 09:44 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Question On Tilt Steering Column
from my 88 is part of the firewall mount there?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-28-2015, 09:57 AM   #3
Titomars
Titomars's Avatar
There are two spring clips that go where the N/S switch goes. The clips snap into place and the N/S switch screws to them. You will have to use the ones from your non tilt column for your new column.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 07-28-2015, 10:13 AM   #4
11555wally
Thanks for the pics and the info. Titomars, would you say that is correct for a 86 column? It will all be clearer I'm sure when I pull out the existing column. Thank you
Old 07-28-2015, 10:27 PM   #5
1774btcrew
1774btcrew's Avatar
Your 86 will not use spring type clips and screws. The neutral safety switch snaps in. You can use the one off your existing column
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 07-28-2015, 11:54 PM   #6
Titomars
Titomars's Avatar
No I am not sure. Once we pass 1981 it goes into a grey area for me.
Old 07-29-2015, 12:30 AM   #7
1774btcrew
1774btcrew's Avatar
Please read my above post. I rebuild A LOT of tilt columns so I am sure it is correct!
Old 07-29-2015, 07:27 AM   #8
11555wally
I'm sure you are correct. I got into my 1986 Shop Manual and found a drawing in the back of the Chassis Electrical section that shows just the 2 holes on the side where it might snap in. Thanks a lot for the info.
