Old 07-31-2015, 05:54 PM   #1
11555wally
Question on 86 Fleetside Short Bed Box
I looked at a short bed fleetside box today that was said to be 79-87. It looked very much like my 86 with a couple of unexplained differences. The main thing is that the floor of my bed is all one piece. The one I looked at today had one large piece and then a small piece in front of the wheel well and one piece at the rear of the wheel well. It looked like it was original with seam sealer at the joint. The other minor point was some sort of a sheet metal guard near the opening for the gas filler tube. Could this have been an earlier/later model. Everything else looked the same as I could remember mine looking like. Appreciate some comments on this. Thanks
11555wally is offline   Reply With Quote
Old 08-01-2015, 10:50 AM   #2
KrazyRay
KrazyRay's Avatar
Re: Question on 86 Fleetside Short Bed Box
The sheetmetal at the filler is for 79-83 beds. 84 up use the plastic filler mount.
KrazyRay is offline   Reply With Quote
Old 08-01-2015, 10:58 AM   #3
11555wally
Thanks KrazyRay. The sheet metal that I was referring to was below where the filler tube would go, kind of like a stone shield. Do those earlier models also have a 3 piece bed? Thanks
Old 08-01-2015, 11:24 AM   #4
KrazyRay
KrazyRay's Avatar
Yes the driver side is patched in on the last 6" on the edge.
Old 08-01-2015, 11:46 AM   #5
11555wally
That's the info I was after. Thanks a bunch. Do you know off hand if that box will bolt right up to my 86, plastic gas tank filler and all?
