Old 08-02-2015, 04:48 AM   #1
NotaBronco
NotaBronco's Avatar
What rear driveshaft will work for a Blazer?
Could I steal one from another 67-72, or are Blazers a different length. Or if anyone has one lying around they would be willing to part with?!! Thanks!
NotaBronco is offline   Reply With Quote
Old 08-02-2015, 07:44 AM   #2
1tuff71
1tuff71's Avatar
Re: What rear driveshaft will work for a Blazer?
I would have to say even though many parts from pickups to Blazers are interchangeable I will say the drive shaft won't fit only due to the fact its not the right length. U- joints are the same if its a 1/2 ton but that's it.
Bought this thing bone stock with intentions to just add a lift and tires and the next thing I knew it was on my garage floor in a million pieces. Sometimes the best laid plans........
1tuff71 is offline   Reply With Quote
Old 08-04-2015, 08:37 AM   #3
Chulisohombre
Chulisohombre's Avatar
Two and four wheel drives are different length. Most early Blazers up til 77-78 will be close to Same length and a 1310 u joint. Or you can have one built for a couple hundred. In a pinch you could take one from a pickup and cut it down and use it. Better to have a professional do that as well though.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 08-04-2015, 09:47 AM   #4
1rippen6
I may have one laying around I will look tonight
1rippen6 is offline   Reply With Quote
Old 08-05-2015, 11:25 AM   #5
1rippen6
Probably will not be able to check until next week Sorry
Old 08-09-2015, 08:09 PM   #6
Jdubs71
Jdubs71's Avatar
If you have a local shop near you that builds custom drive lines check them out, they're are usually reasonable to have a new one built.
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 08-10-2015, 04:29 PM   #7
1rippen6
Sorry I don't have any that don't have some kind of issue with it
