Old 09-08-2003, 04:11 PM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
wanted: control arms 71-72 C/10
I was thinking about starting to collect the parts to rebuild the suspension on a 71 C/10. I want to sandblast and powdercoat without having the truck down.
This is just an idea but If any one has a set of 4 (upper and lower) control arms send me a price with shipping to 10310 (business address)
Rich
1972 K5 Blazer CST Click HERE
Old 09-08-2003, 06:24 PM   #2
MOTHERTRUCKERS
240.00 powder coated gloss black including shipping.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 09-08-2003, 10:57 PM   #3
mcmlxix
mcmlxix's Avatar
I have my own sandblaster and powdercoating equipment. I want to do it cheap myself.
Rich
Old 09-09-2003, 08:19 AM   #4
MOTHERTRUCKERS
O K non coated 110.00 with shipping.
Old 09-09-2003, 09:08 AM   #5
cwilli84
1FINE69
cwilli84's Avatar
Mother trucker , do those arms come with the shafts installed on them. Let me know
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD
cwilli84 is offline   Reply With Quote
Old 09-09-2003, 10:22 AM   #6
MOTHERTRUCKERS
Yes they do, the ball joints are in them also.
Old 09-09-2003, 01:42 PM   #7
clean71
clean71's Avatar
I'm looking for a set of lowers. Anybody have those? How much shipped to 85367? Thanks.
CPO U.S. Navy(Ret)
1972 GMC Jimmy 4x4 Custom
1972 GMC Jimmy 2x4 Custom
clean71 is offline   Reply With Quote
Old 09-10-2003, 01:32 AM   #8
alta-aj
clean71 - I have a set.
I have a set of lowers. I'm looking for $70 + shipping.
alta-aj is offline   Reply With Quote
Old 09-10-2003, 09:08 AM   #9
ucmydust68
fuel
i have lowers. just pulled them off, 50 + shipping!!! pm me if ya want em!
ucmydust68 is offline   Reply With Quote
Old 09-10-2003, 10:31 AM   #10
clean71
clean71's Avatar
Forgot to ask. Ineed these for my 68. Are all the arms the same? Thanks.
CPO U.S. Navy(Ret)
Old 09-10-2003, 10:32 AM   #11
ucmydust68
fuel
im not really sure, these have disc brakes and i think that 68's are drums so they might be different
Old 09-11-2003, 09:08 PM   #12
jmanz69
Careful, they attack...
jmanz69's Avatar
I have a pair from a 69. It had drums, and the drum and disc ones are different, but only for the lowers. Mine need blasted, but are cheap. Only $25 plus shipping. They also need new ball joints and shafts too.
jmanz69 is offline   Reply With Quote
Old 09-11-2003, 09:44 PM   #13
mcmlxix
mcmlxix's Avatar
I thought all the arms were the same, upper and lower. I thought it was the ball joints that made them fit drum or disc spindles. If you look at all the drop spindle options, I think it says 67-70 must use 71-72 ... wait, maybe that was tie rod ends ... help... one of the parts guys should know .... mothertrucker, wes,rick ???
Rich
Old 09-11-2003, 09:48 PM   #14
jmanz69
jmanz69's Avatar
It's the steering stops and the ball joints that are different. If you use 67-70 lower control arms, you will have a very wide turning radius. The 71-72 arms are a slightly different design, that allow for a sharper turn radius. That is the difference between lower arms. 67-70 arms can be used to change to disc by changing the ball joint to a 71-72 type, but you will not be able to turn as sharp.
Old 09-11-2003, 10:06 PM   #15
MOTHERTRUCKERS
mcmlxix Not ALL drop spindles need tierod or ball joint changes! Check the suspension section of our online catalog.
Old 09-12-2003, 12:54 AM   #16
cheyenne10
cheyenne10's Avatar
jmanz69
Can someone confirm that 68-70 a-arms are differnt than 71/72 version. That would change a lot for myself as well as others.
Bob
cheyenne10 is offline   Reply With Quote
Old 09-12-2003, 07:07 AM   #17
jmanz69
jmanz69's Avatar
Why don't people believe me... Anyway, here are pics to show the difference. The first is a 71-72 arm, see how the steering stop is rounded off at the top....
Old 09-12-2003, 07:09 AM   #18
jmanz69
jmanz69's Avatar
This is the 67-70 style. The steering stop is more pointed. That and the ball joints are the differences. You can use 67-70 lower arms with no problems, and you probably won't really notice much difference.
Old 09-12-2003, 09:02 AM   #19
mcmlxix
mcmlxix's Avatar
I believe you ... so what makes the truning radius so large? And when you say large, how large? can you still make a u-turn in a two lane street or do you have to make an X-Y-Z turn? (X-Y-Z turn means back and forth 26 times just to turn around)
Rich
Old 09-12-2003, 09:06 AM   #20
cwilli84
1FINE69
cwilli84's Avatar
I thinkits due to the indicated bumps hitting the inside of the spindle and decreasing the angle at which the tire can rotate inboard/outboard. I think I got this right.
Old 09-12-2003, 09:48 AM   #21
jmanz69
jmanz69's Avatar
cwilli you are right, the disc spindles hit differently than the drum spindles do. Each control arm was made to work with the correct spindle. But you can still turn. I don't know exactly how much wider your turn radius will be. I am using the 71-72 spindles and the 71-72 control arms.
Old 09-12-2003, 10:05 AM   #22
mcmlxix
mcmlxix's Avatar
so if you "adjust" (read: cut,hack,torch,beat) them, the turning radius issue will be solved? It has nothing to do with the over all length / width / design of the arm itself?
Rich
Old 09-12-2003, 10:35 AM   #23
jmanz69
jmanz69's Avatar
Correct, if you beat the hell out of it, it will work. I have heard of people doing it. There is no difference in size lenght or anything. Just the steering stop and the ball joint.
Old 09-12-2003, 12:38 PM   #24
cheyenne10
cheyenne10's Avatar
I believe!!
Sorry if I offended anyone. I just wanted to confirm what is being said. I studied your pictures and I see what you mean on steering stop.
Now that said does a stock 71-72 truck have a shorter turning radius vs the earlier ones which turned a bigger circle? It was stated above that "you will have a very wide turning radius" or is it a combo of early lower arms and new disc spindles that increase radius over stock drum setup.
Bottom line is I want tight turn radius and disc brakes with 2.5" lowered spindles. I only want to do this once.
thanks for all advise.
Sorry if this dettracts from original post on collecting suspension parts and price.
Bob
Old 09-12-2003, 01:18 PM   #25
jmanz69
jmanz69's Avatar
I believe it's the combo of the early arms and spindles and the 71-72 spindles and arms. Each was designed to work with the other. Meaning the 71-72 spindles were meant to work with the 71-72 lower arms. If you use aftermarket spindles, ask them what year they work with. Some spindles are made to work with the 67-70 arms. Which means they should have the turn radius in mind. Hope this helps. and good luck.
