08-14-2015, 10:04 AM | #1 |
Factory primer color
Looking at some of the trucks found in fields etc on this site and I've noticed some of them have black primer and some have red. My 65 Suburban had black. Does thr factory location have any bearing on the color? Or is it the final exterior color?
08-14-2015, 10:57 AM | #2 |
Re: Factory primer color
Yes - there is some variation in primer color (black vs red) based on final assembly location. All vehicles produced at the same plant will have the same primer color regardless of exterior final color coat.
Some vehicles will also have different colored primer on the body/cab/box vs front end sheet metal, since those were often painted in different areas of the plant. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-14-2015, 05:56 PM | #3 |
Thanks Keith. That answers my question
08-14-2015, 07:18 PM | #4 |
I've been working on my box and there was lots of heavy red primer there but the hood all by itself is now showing more black than green.
08-14-2015, 08:11 PM | #5 |
I found green on '62 from L code for LA.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 08-14-2015 at 08:17 PM. |
08-28-2017, 10:42 PM | #6 |
UPDATE:
I stripped my door frames down last week, and found red primer under the original Light Blue paint. |
07-07-2021, 10:56 PM | #7 |
TTT
Got into a discussion with some truck buddies tonight Freemont truck |
07-08-2021, 11:09 PM | #8 |
On this generation of trucks, it looks like they used red on the cab and doors and black on everything else.
07-10-2021, 01:11 PM | #9 |
07-15-2021, 01:56 PM | #10 |
Almost every 60-66 was black on bed and front sheet metal. Red on cab and doors. Suburban main body red oxide front sheet metal black. On a very rare occasion there can be a yellow/green base on beds. Canada is what Im thinking at the moment may be the different with all red oxide but not much to go on there
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
07-15-2021, 02:22 PM | #11 |
Who Changed This?
Back in the '60s it was a common problem for lighter colors (especially yellow) to look different between the hood and fenders, and the rest of the car. I forget with was primed which color, though. This was on cars, though I wouldn't expect it to be different on the trucks.
07-16-2021, 09:00 AM | #12 | |
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
07-16-2021, 10:46 AM | #13 |
My 66 GMC original black paint truck is showing some green underneath also. Heres another sample of the green primer on NOS Suburban quarter panels .
07-17-2021, 09:43 AM | #14 |
WOW! How can you have an NOS quarter panel but not have a 6 cyl fan shroud?
