08-20-2015, 01:12 PM | #1 |
Cummins 6bt with brake booster ?
Hey guys, almost ready to test fit my first gen cummins into my 72k20. Any way to keep a brake booster and not convert to hydroboost? I could use the stock cummins vacuum pump then. Just worried I won't have the room. Thanks!
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
08-20-2015, 01:42 PM | #2 |
Re: Cummins 6bt with brake booster ?
Reaching back in my memory, I don't think you can as it actually hits... The other problem I ran into was that the original intake hit my master cylinder.
-Scott 1972 Chevy K20 Picture Gallery Build Thread 1930 Chevy AD Picture Gallery 1929 Ford Model-A Picture Gallery 1975 Triumph TR-6 Picture Gallery |
08-20-2015, 04:55 PM | #3 |
6>8 Plugless........
Build a new upper intake if you have to. I've got them in there with the factory booster. With a p-pump engine it's a lot more difficult. That isn't with an autoworld cross member and the intake on that one is from an industrial application.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-20-2015, 07:05 PM | #4 |
Thanks!! Gives me an idea what I'll be up against
08-21-2015, 11:39 PM | #5 |
I put a bbc in a 69 Camaro once and had some fitment probs around the booster. Ended up using a booster out of a fiero . They are nice and small . Just something to consider .
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
