Old 08-24-2015, 03:38 PM   #1
mlbrickey
Need advice/ assist please
I've been working on my 70 LWB with 350 SBC. I removed the broken ram horns and have gone with headers for now. My question/ issue is now I can't seem to get my alternator to on correctly. I know there was a bolt in the manifold. Is my option now to get different brackets? There was an issue with clearance before with my valve covers. What might be my best option to sort this out?
Thanks,
Mitch
mlbrickey is offline   Reply With Quote
Old 08-24-2015, 03:56 PM   #2
BlackedOut67shorty
BlackedOut67shorty's Avatar
Re: Need advice/ assist please
let me try and get a pic of mine, it was a farm engeneered bracket that was on a tow truck with headers. gimmie a couple min to get that pic
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 08-24-2015, 04:04 PM   #3
Jurassic-1
Jurassic-1's Avatar
You sometimes can use an early header bracket or modify an early Impala type alternator bracket. These were bolted to the manifold but with little modification and a couple of spacers it can be used.
Jurassic-1 is offline   Reply With Quote
Old 08-24-2015, 04:08 PM   #4
mlbrickey
Thanks, it is just one of a few more things I need to finish to get my truck back on the road.
Old 08-24-2015, 04:13 PM   #5
BlackedOut67shorty
This is to my power steering. Not sure how your alt mounts but ill bring up how mine mounts
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 08-24-2015, 04:14 PM   #6
BlackedOut67shorty
My alt mount
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 08-24-2015, 04:15 PM   #7
BlackedOut67shorty
My alt mounts on the passenger side
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 08-24-2015, 04:46 PM   #8
mlbrickey
I will get some pictures up later this evening. Mine is currently on the driver's side with what I assume is the stock bracket. The upper arm is connected to the front of the intake and the lower is connected to the front of the water pump. After I took out the exhaust manifold and replaced it with headers it there is a bolt hole on the lower that is no longer usable.
Old 08-24-2015, 05:38 PM   #9
cooperhw
cooperhw's Avatar
Is it "no longer usable? or just away from the header flange? My power steering had the same issue. I just cut a piece of small pipe that fit over the bolt to length and slipped it between the header flange and the bracket. Installed a longer bolt with a lock washer and thread locker, and done.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 08-25-2015, 12:15 AM   #10
swamp rat
swamp rat's Avatar
First thing you need to figure out is do you have the long or short water pump setup, is the alt on the driver or passanger side? stock is a short water pump with the alt on the driver side, if its on the passanger side its a long water pump setup used from 73 and later. if you have the long W/P setup it means you have a replacement engine.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-25-2015, 10:42 AM   #11
mlbrickey
Here are a couple of pictures of what I have cuurently.
Old 08-25-2015, 10:54 AM   #12
scotts72heavyhalf
scotts72heavyhalf's Avatar
Do these help?
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 08-25-2015, 10:55 AM   #13
scotts72heavyhalf
Number 2
Scotts72C10
Old 08-25-2015, 10:56 AM   #14
scotts72heavyhalf
Number 3
Scotts72C10
Old 08-25-2015, 11:29 AM   #15
smoked68
smoked68's Avatar
Hi, I had tried every imaginable bracket set up over the years, none worked well with headers. So I found on line at Jegs, parts #555-50546, Jegs SBC Billet alt bracket at 62.99. It is just simply the best. Looks great while doing its job. Also try some Headman headers for our trucks. They fit perfectly, and I have a 4 spd. Ceramic coat is very pleasing to the eyes. I thank you, Mike
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 08-25-2015, 11:40 AM   #16
swamp rat
swamp rat's Avatar
A quick search of less than 2 minutes in the the advanced search option using the words "alternator header bracket" produced this thread.
http://67-72chevytrucks.com/vboard/s...eadder+bracket
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-25-2015, 01:37 PM   #17
mlbrickey
I appreciate all the info. I will figure out from what I've learned.
Old 08-25-2015, 10:23 PM   #18
airbrushguy
I used the same Chevy bracket that scotts72heavyhalf used except I mounted it on the other side. Good luck!
airbrushguy is offline   Reply With Quote
Old 08-26-2015, 09:33 PM   #19
swamp rat
swamp rat's Avatar
You have that bracket upside down and it works?? closeup pic's please, Thanks.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-27-2015, 10:38 PM   #20
airbrushguy
Ill get them for you this weekend. Wait, maybe this would help...
Old 08-27-2015, 10:48 PM   #21
swamp rat
swamp rat's Avatar
Thank you!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-28-2015, 12:21 AM   #22
Z10
Z10's Avatar
My contribution:
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 08-30-2015, 01:28 PM   #23
mlbrickey
Thanks for all the pictures and info. I'm now on the hunt for a bracket that bolts to the head. I thought I had found one at a local parts yard but, it was not. I looked at some one summit but, would prefer a more stock looking bracket. I will search more locally and check out other places as well. Once again thanks fellas.
