Old 09-01-2015, 11:26 PM   #1
Cannoncollector
Need 7.00-18 rims and tires or equilvilant
Just bought 69 c-30 ...has split rims, and need some, or equivalent tubeless?,..need help
Cannoncollector is offline   Reply With Quote
Old 09-02-2015, 04:18 PM   #2
Cannoncollector
Re: Need 7.00-18 rims and tires or equilvilant
Here are some photos of them...also I am going to be buying new rocker panels, and under cab supports for the front body mounts ,and wonder which is the best fitting and quality
Old 09-19-2015, 12:13 AM   #3
bigrigpardo
whats the bolt pattern? I know there are ford 19.5 standard rims on the newer duallys and ups bread truck types. look for them. if you have the 8x6.5 bolt pattern a used set of them is the way to go. well that was my plan for that truck anyways.
bigrigpardo is offline   Reply With Quote
Old 09-19-2015, 12:15 AM   #4
bigrigpardo
like this. just check all your measurements but these are non split and you can get tires easily.
Old 09-19-2015, 12:17 AM   #5
bigrigpardo
oops forgot linky
http://www.ebay.com/itm/GM-DUALLY-8-...9fcfc7&vxp=mtr
