09-09-2015, 11:49 PM | #1 |
Pump to Carburetor Fuel Lines, what are you all using?
I'm going to be installing a crate motor in my 69 C1500 in the near future, replacing the original 307. I will also be installing an Edelbrock performer manifold and carb that I've laying around for years. I plan on using an original style fuel pump, which I believe has a 5/16" inlet/outlet. I have seen a few different braided hose kits that seem to use a larger 3/8" hose. Ideally, I'd like to use all steel lines with an inline fuel filter. But who sells all the fitting I'd need? What are you guys using?
09-09-2015, 11:55 PM | #2 |
Re: Pump to Carburetor Fuel Lines, what are you all using?
Stock metal tubing.
09-10-2015, 12:26 AM | #3 |
-6 braided hose. Much easier to work with I think. Summit fittings are just like Russels and easier to use than Earls. Just make sure to use nitrile lined hose(not natural rubber)to stand up to "Obama gas".
09-10-2015, 12:28 AM | #4 |
Home bent tubing with a rubber jumper gas line by the pump.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
09-10-2015, 12:38 AM | #5 |
Those A/N fittings and braided hose look great!
I have this job coming up and I am going to use 5/16" Poly Armor tubing from NAPA, putting in an inline filter (NAPA) with bubble flares and short bit of hose. I'll make my own double flares for the pump and carb fittings with a Craftsman Double Flare Kit. |
09-10-2015, 02:34 AM | #6 |
origonal steel line
09-10-2015, 06:35 AM | #7 |
Steel brake lines the whole way...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
09-10-2015, 07:33 AM | #8 |
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
09-10-2015, 08:28 AM | #9 |
One nice thing about runnin a Q-jet is that you can use OEM replacement lines. Cheaper way is to bend your own steel lines but takes some skill or at minimum a lot of trial and error! The braided is the easier DIY and has the racer look to it but comes at a $$.
09-10-2015, 09:47 AM | #10 |
Factory steel to QJet. Get a good bender it's not hard to make your own.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
09-10-2015, 12:01 PM | #11 |
09-10-2015, 12:55 PM | #12 |
Agreed, always like the 348 and 409
The lid is stuck on my jar of anti seize |
09-10-2015, 01:34 PM | #13 |
Its just a mild 300 HP daily driver, but its different, Thanks guys.
09-10-2015, 08:48 PM | #14 |
Steel brake lines here as well. The last thing I wanted was an engine fire due to rubber hose melting down.
09-10-2015, 09:01 PM | #15 |
copper coated steel/zinc hard lines.
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
09-10-2015, 09:18 PM | #16 |
steel lines, have fun making em too (seriously) - you'll be glad you did.
Hamjet - you mentioned you used brake lines. What size? Normal larger size brake line is 1/4" and I've always thought the smallest acceptable fuel line was 5/16" (with the larger cfm setups getting 3/8" lines). Love the W motor btw, looks great! |
09-10-2015, 09:22 PM | #17 | |
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
09-10-2015, 09:31 PM | #18 | |||
"I ain't nobody, dork."
Here is the line on the bench. Here it is installed. Here is the tubing bender and flare tool I used to do it. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
09-10-2015, 11:00 PM | #19 |
I'm using 3/8" 250 psi rubber hose, which should outlast me! It's secured with clamps above the fuel pump and on the intake manifold, so it won't flop around.
I may eventually bend a hard line, but it's a PITA when using a Holley with the fuel inlet on the driver's side. (What was I thinking when I bought that carb?) I also have a fuel filter between carb and pump which makes using hard line even more difficult.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 09-10-2015 at 11:16 PM. |
09-11-2015, 07:24 AM | #20 |
PITA? is rebuilding due to the massive fire due to laziness and rubber fuel lines
09-11-2015, 07:32 AM | #21 | |
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. Last edited by hamjet; 09-11-2015 at 02:32 PM. |
09-11-2015, 07:43 AM | #22 |
Not the best pic, but SS hard-line with an in-line AN fitting fuel filter.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
09-11-2015, 11:13 AM | #23 |
X2 steel the entire way. No point in have a 10,000 to 20,000 thousand dollar truck burn down from a 2 dollar hose.
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
09-12-2015, 09:01 PM | #24 |
So, you don't have a rubber fuel line at pump inlet? And looking at my setup, what would cause "massive fire"?
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
09-13-2015, 01:28 AM | #25 | |
