09-10-2015, 05:06 PM | #1 |
and son
700r4 Lockup Solenoid vacuum switch
Hey guys, I have a 1986 Burb 350sb 700r4 trans just did an intake carb swap, headers dual exhaust in very near future. So no emissions crap, took it all off as well as all vac lines except vac adv for dist and power brakes. Never had a 700r4 before. I got the proper bracket for the TV cable and throttle linkage part to correctly hook the TV cable to the edelbrock carb and adjusted it. Everything runs and shifts perfect around town for the test drives I have given it. Now I just need to hook up the lockup solenoid. I have the factory harness plugged into the trans it comes up to the engine and plugs into a vac switch that has two vac ports on it. Can I hook this vac switch up and have this work as it did from the factory? or do I have to buy some kinda aftermarket lockup kit??? Thanks in advance for your response... PS what happens if I do not hook up this lock up switch? can I damage the trans? what is the purpose of the lockup switch? does it just lock up at highway cruising speeds? only in OD? new to the 700r4 so forgive my ignorance :P always had either a 4 speed manual or a turbo 350
1970 C10 8ft Fleetside The build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=289628 1986 GMC 3500 2wd CrewCab Dually 454 1994 Chevy 2500 2wd Ext Cab 8ft bed |
09-10-2015, 06:23 PM | #2 |
and son
Re: 700r4 Lockup Solenoid vacuum switch
Might have answered my own question so I will post what I found out today.
Did some asking around and some google searches. I talked to a guy from Mad Dog Transmissions in GA Great guy, very helpful. Could have easily said I needed to buy something and try to sell me but he did not. He said unless I was really concerned about highway fuel economy and or had a really revving rear end gear 4.11 4.56 etc that I did not need to have the lockup hooked up. I have 2.73 rear gears in my Burb so I really have no use for dropping rpms at highway speeds anymore than I already do when I'm in OD So with that said I'm leaving it unhooked PS Anyone near Hagerstown MD 21740 have a good rear for my 86 Burb with 3.73 gears?
09-10-2015, 08:28 PM | #4 |
Sound like you already have an aftermarket unit. TCI I think. So long ago when I got mine. Still works great. Locks up a clutch in the torque converter kinda making it like a manual trans.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
