under floor brake pedal.. how to install the pedal through the floor ?
Hy together
for getting a clear firewall i switched to a under floor brake assembly. The setup is already installed, but i am still looking for a good solution how to get the pedal through the groundfloor ... ?? Which rubber rosette did u use ??? Some pics would be great !! :-) Thanks again CU AChim |
Re: under floor brake pedal.. how to install the pedal through the floor ?
Stock pedal and grommet, most use the same hole.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
what truck are you working on?
any truck in this forum would already have the pedal thru the floor with the mc underneath if your setup is aftermarket and doesn't match the hole, just cut out the fiber washer slot and move it over to match task force trucks have a pocket under the floor that a fiber washer slides in fiber washer doesn't impede the travel of the pedal thru the floor like rubber would
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Hy
i do have 51 pickup with a self made under floor brake setup. @ ogre i dont understand what u mean with a fiber washer ? do u have any pics e.g. ?? At the moment i do have a hole 45x20mm where the pedal goes through... thx Achim |
here is a link to some of the felt seals.
http://www.ecklerstrucks.com/chevy-truck-floor-seal-brake-or-clutch-pedal-1947-1951.html?cm_mmc=PLA-_-$50_orless-_-Classic%20Performance%20Parts%20CPP-_-61-247934-1&gclid=CNCNt_vDlsgCFZKAaQodjmANzA |
