Old 09-11-2015, 04:25 PM   #1
zacthrasher
zacthrasher's Avatar
What diff size to go with 6.0 4l80E?
Trying to determine what diff gears to put in. Now I have the old original 3.08 but I will be going to limited slip and not sure whether 3.73 or 4.10 would be better. At this time I have about a 28.5" tall tire but looking to go a little bigger to about a 31" tire in the future. Any opinions or what is every one else doing with this combo.
Thanks!
My 67 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=473825
zacthrasher is offline   Reply With Quote
Old 09-11-2015, 07:42 PM   #2
CarterD2015
CarterD2015's Avatar
Re: What diff size to go with 6.0 4l80E?
I guess it depends on what you will be doing with your truck. You may want to give a little more info so that you receive a better answer.
Dennis
37 ford coupe
68 short narrow
72 short wide
CarterD2015 is offline   Reply With Quote
Old 09-11-2015, 07:44 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Those are both the "fan favorite" diff ratio's on these swaps. I like the road manners that the 3:73 offers up, since you can run ~70 at just over 2k (each truck is a little different of course).
The 4.10 is a little more popular for the M6 guys, but you can still totally run it if your truck spends more time at the track or isn't doing long stretches of 70+ highway. I'll tell you what though....with the overdrive trans, either option feels WORLDS better than the old 3spds.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-11-2015, 08:28 PM   #4
crazy longhorn
Fabricate till you "puke"
I dropped a 3.73 in my 02 Silverado, awesome combo....it let that little 4.8 run! My longhorn is a tick different animal....stick shift, 6 spd ROD behind the 5.3. On a 29" tire, 3.42 gears....I have all the gear that I need! She will cruise @ 105 mph, @ 3100-3150 on the tach Once again, it depends on you useage....longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-12-2015, 02:56 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by crazy longhorn View Post
cruise @ 105 mph
Old 09-12-2015, 07:59 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What diff size to go with 6.0 4l80E?
Well my 4:10 gears and 4L80E run at 2600RPM's at 80MPH! My truck runs the interstates all the time ever since I bught it back in 1986. I just did a round trip to my dad's 280 miles today.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-12-2015, 08:14 PM   #7
Advanced Design
Advanced Design's Avatar
My burb has a 6.0 with 4L80E and 3.73 gearing. Very happy with the combination.
Advanced Design is offline   Reply With Quote
