Old 09-12-2015, 10:20 AM   #1
Dubnova
LS Air Intake Pics?
Anybody have any LS swap air intake pics? I'm getting close on the install and I was wondering how you guys routed your air tubes? Thanks
[IMG][/IMG]
[IMG][/IMG]
Dubnova is offline   Reply With Quote
Old 09-13-2015, 03:54 PM   #2
Mathew21
Mathew21's Avatar
Re: LS Air Intake Pics?
First beautiful truck!
You might have better luck posting this question in the LS swap area. I'm trying to figure out how to run my cold air intake right now. I will post up some pictures when I get it figured out.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 09-13-2015, 06:28 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You def will have better luck in the LS section. FWIW, here's a video I did about building my cold air box, and it shows the intake we used and the changes we made.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-13-2015, 07:35 PM   #4
oldies1938
Hope this helps
oldies1938 is offline   Reply With Quote
Old 09-13-2015, 07:50 PM   #5
Mathew21
Mathew21's Avatar
www.youtube.com/watch?v=2KXfR4fIb8c
Great video!
Old 09-13-2015, 10:08 PM   #6
NevEno
NevEno's Avatar
Here's one I seen at a car show Saturday. You'd have to relocate the battery.
You can find me on Instagram @neveno_cten
NevEno is offline   Reply With Quote
Old 09-23-2015, 09:23 AM   #7
eagleuh1
eagleuh1's Avatar
I ran mine down to where battery used to be, moved battery to drivers side. Used 4 inch semi exhaust pipe 90's cut and trimmed, welded to fit with K&N cone filter. Used straight rubber sleeve and 2 heavey clamps to connect to TB on 2005 5.3 in 68 Chevy C20. Look at my build pics.
eagleuh1 is offline   Reply With Quote
Old 09-23-2015, 09:56 AM   #8
Matt Cramer
I didn't. Just put a cone filter on the throttle body. I'm running speed density, so there's no MAF.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 09-23-2015, 08:36 PM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: LS Air Intake Pics?
I used it on my 305 TPI motor and now on the 6.0 Ls motor.
Caddy air box modified by me. 4" ninty with 2 couplings from Lowes mounted on the radiator support where the old voltage regulator went.
Some day I'll modify the top so I can run a solid tube over to the intake.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-25-2015, 11:39 PM   #10
RocketKing
RocketKing's Avatar
Rex
RocketKing is offline   Reply With Quote
Old 09-27-2015, 08:32 PM   #11
mooseknuckles
mooseknuckles's Avatar
here's mine.. spectre 4", $150 from summit. half the price of a K&N.
mooseknuckles is offline   Reply With Quote
Old 09-28-2015, 02:43 PM   #12
bs46488
I didn't do the LS swap in my truck, but for my Nova I bought a different elbow and sent the intake under the hose, not over.
bs46488 is offline   Reply With Quote
Old 09-30-2015, 01:32 PM   #13
LS64C10
LS64C10's Avatar
3.75" x 3.5" Reducing 90 with Vibrant 45 tubing part #2890 and a 9" Spectre
LS64C10 is offline   Reply With Quote
Old 09-30-2015, 02:05 PM   #14
josueh95
josueh95 is offline   Reply With Quote
