09-12-2015, 03:35 PM | #1 |
Gap between hood braces and hood skin
Does anybody else have a huge gap between the hood braces and hood skin? The po had filled this entire area with expanding foam on my truck! I can push the skin down to touch the braces but then it creates a large valley in the hood. When the contour of the skin is correct I get these large gaps?
online photo sharing |
09-12-2015, 03:42 PM | #2 |
Moderator
Re: Gap between hood braces and hood skin
There are foam pads that go between the braces and hood skin. Classicheartbeat sells a quality replacement set.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-12-2015, 03:52 PM | #3 |
Yep, my Goodmark replacement hood is filled with some sort of expanding foam.
09-12-2015, 04:04 PM | #4 |
Moderator
Yep, what they said. The gap is factory. You just need the foam padding.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
09-12-2015, 04:09 PM | #5 |
Cool. Thanks guys!
09-12-2015, 05:23 PM | #6 |
you can fold up reminents of a pizza box and wedge it home
09-12-2015, 09:41 PM | #7 |
i used urethane windshield adhesive and ran a bead between braces and skin. it really did the job .the hood sounds solid when i close it plus its just flexable enough so you cant see where the braces are on the outer skin. of course my gaps were not as big as yours are
