09-15-2015, 07:38 PM | #1 |
How to cut 3600 bed to 3100
I ended up with a 3600 bed. I have searched on this forum and on Google with not a lot of luck on where to cut it down to make it a 3100. Help the dummy? My Google-fu is usually pretty strong. I'm disappointed in myself for asking, trust me.
Is it as simple as cutting 10" out of the front? |
09-15-2015, 11:23 PM | #2 |
Re: How to cut 3600 bed to 3100
09-15-2015, 11:35 PM | #3 |
That's super helpful! So the distance from the rear bumper to the center line of hte wheel well is 41 7/16" on both of them. I just read a build where a guy thought about cutting 9" but went with 7" instead and was very happy with it. Better to cut less than too much!
09-16-2015, 08:40 AM | #4 | |
crossfire84's thread: http://67-72chevytrucks.com/vboard/s...d.php?t=530662
Pics of Finished 49 AD: https://www.flickr.com/photos/103194...7686536275403/ Pics of build process: https://www.flickr.com/photos/103194...57684031425944 |
09-16-2015, 09:30 AM | #5 |
Hope I was clear that that even though you are not doing a frame cut, the 9-1/4" measurement applies to the bed, also. ...9" off the front of the bed would probably work, but 7" would not be enough. Even so, after we had a 1/2 ton bed on a 1/2 ton length frame, we moved the rear axle back a little more then an inch to center the wheel in the fender opening. Many builders do this last bit.
09-16-2015, 10:11 AM | #6 |
All I know is when you go to cut it, don't cut that section out and re-weld it. Remove the stake pockets by drilling out the spot welds and then cut off what you want then plug weld the stake pocket back on.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
09-16-2015, 11:43 AM | #7 |
Brian has a good point there. The spot welds cut out pretty easy with a spot weld cutter and it makes a lot better all around job of it.
There is a 9-1/4 inch wheelbase difference between the trucks but the difference in the length of the beds is 8-7/8 according to the GM herritage printout for the 53 models which have the best drawings. You would want to cut the bed sides down pretty close to exact if you are planing on using a precut bed wood kit. A slight length adjustment to center the wheels and get the space between the back of the cab and the front of the bed just right (especially on a frame swap) wouldn't be a big deal if you cut your own wood for the bed. https://www.gmheritagecenter.com/doc...olet-Truck.pdf
09-16-2015, 08:36 PM | #8 |
I should clarify: I am using an S10 frame, so it sounds like 8 7/8" is the cut to make to the bed. No cuts to the frame. I will be making a custom bed floor- no kit.
So you are saying the stake pockets need to be moved so they are on the front edge of the bed? How many places is it spot welded? |
09-16-2015, 08:44 PM | #9 |
Cutting a long bed down is pretty close to breaking a mirror, or having a black cat cross your path........
09-16-2015, 11:15 PM | #10 | |
http://www.hotrodders.com/forum/basi...ls-222549.html Brian
