Old 09-20-2015, 10:03 PM   #1
ssuesens
ssuesens's Avatar
wiper switch - help me troubleshoot
Wiper switch on my 71 has not functioned right since I've owned it. I can turn the knob to the first or second click and nothing happens. When I push the knob in the wipers take one pass and then quit. I do not have a washer tank or washer fluid lines on the truck, not sure about a washer pump. Before I order a new switch can someone offer any ideas? I removed the switch and cleaned the terminals today. How would I test the switch with a voltmeter?
"Life is too short to use cheap zip ties"
64 C10 SWB
71 C10 LWB
72 C10 LWB
ssuesens is offline   Reply With Quote
Old 09-20-2015, 10:49 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: wiper switch - help me troubleshoot
All three wires on the switch are grounds. The switch grounds one wire for high speed operation, two wires are grounded for low speed operation and the third wire grounds the washer solenoid to activate the washers. Make sure that the switch itself has a good ground. You may find this thread helpful....
http://67-72chevytrucks.com/vboard/s...d.php?t=413551
LockDoc
Leon
