How heavy is the bed of the truck???
I have my Porterbuilt air ride on order and I'm gonna take the bed off. How heavy is it? How many people does it take to move?
Tks Kevin |
Petroleum User
Re: How heavy is the bed of the truck???
Id say around 400+ lbs for a long bed. Ive done it easily with four guys. Could work with two strong guys. If you rig up a four wheel cart into a bed stand and let it take a portion of the weight, two guys could do it easily. One guy could do it if you have strong rafters/trusses with eye screws, and lift it off with straps and then drive the truck away. Lots of ways to do it
![]() 1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
When my swb bed (wood) rotted out, the original owner made his own bed, complete with bedsides, out of 1/8 steel plate. It is seamlessly welded in there with plug welds to 4 bolts in the bottom. He removed it once, alone, on jacks.
I am thinking about building a hoist out of 4x4 blocks and lifting it on straps or just jacking it up like the previous owner. |
DND Trucks
![]() Join Date: Dec 1999
Fwiw,
Not sure on weight but I've removed the bed by myself with an engine hoist and some nylon straps. Then placed it on a 4 wheel steel cart to move it around when needed. |
All about them K’s
![]() Join Date: Jun 2014
I will say if the bed is already junk one man can get it off by himself... It wasn't pretty but like I said the bed was already trash
350- 400 lbs is probably about right for a long bed.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
