09-22-2015, 09:15 PM | #1 |
Starting Shortbed Conversion Tomorrow
hey guys i'm doing a shortbed conversion, i've read numerous threads, watched a lot of videos, and talked to people, and now the weather is good enough so i'm ready. just wondering, is there anything that those with experience doing it could tell me as a little tidbit? thanks so much guys! This site is awesome!
09-22-2015, 09:25 PM | #2 |
Re: Starting Shortbed Conversion Tomorrow
If I read it right, the cabs for short Vs long differ? In what way?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-22-2015, 09:32 PM | #3 |
Moderator
Cabs are the same
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-22-2015, 10:39 PM | #4 |
z cut , under the cab ,and box frame in that 12 inch area when done , stacy david , did it right ,, check out gearz
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
09-22-2015, 11:53 PM | #5 |
09-22-2015, 11:54 PM | #6 |
09-23-2015, 12:04 AM | #7 |
Like some of the articles say, make X reference marks on the frame. Measure multiple time then BURN IT IN.. Yes do the Z cut, you will be glad you did
09-23-2015, 09:29 AM | #8 |
And this thread includes great information on converting the bed.
http://67-72chevytrucks.com/vboard/s...d.php?t=667694 |
09-23-2015, 09:37 AM | #9 |
I'm just glad to be here!
While the link that Advanced Design posted is good and another way to do the work, I believe this is the better way to do the job.
This link has been in the FAQ and is the Z method others have mentioned above. He has lots of great pictures thru the process. http://67-72chevytrucks.com/vboard/s...d.php?t=123624
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
09-23-2015, 09:52 AM | #10 |
aggie that is actually the thread i've studied the most!
thanks everyone for the responses!! |
09-23-2015, 03:42 PM | #11 |
Id be interested so see some updates through this build
09-23-2015, 05:24 PM | #12 | |
09-23-2015, 10:55 PM | #13 |
Harrison I'll definitely keep updates coming. I wasn't able to start today. there was something that came up, but for sure by next monday there should be something!
09-23-2015, 11:23 PM | #14 |
http://www.earlyclassic.com/tech.asp...20No!-Shortbed
Since we know these guys and used their boxing plates, this is the way we did the frame work. I wouldn't hesitate to do it to another truck. |
09-24-2015, 01:33 AM | #15 |
olsmokey,
I literally just did this conversion a couple months ago. The only thing that i did different than what the threads or Gears did was i put the phish plate on the outside of the frame. It was alot easier to weld and i kinda like the look. measure three times, then just go for it. Now, the interesting part is that on gears they used a saws-all for the z cut on the round portion, well i tried this and decided to try something else. I honestly used a jig saw with a metal blade and it worked surprisingly easy! It really is easy, and it will surprise you how simple it is, just do your research and if you have a direct question, ask it here, the help here has been awesome!!! good luck and please post pics. |
09-24-2015, 10:07 PM | #16 |
make sure that frame is true while you have it apart....string and tape measure all you need..
