Old 09-29-2015, 12:46 PM   #1
lts70
1970 Daily Driver
lts70's Avatar
5.3L Turbo Questions
Recently purchased a 5.3L/4l60E setup out of a 2007 2wd Silverado with 60,000 miles on the clock. I am in the process of pulling my 327/nv3500 out of my 70 SWB Chevy to make room for the new power plant. The new to me 5.3l already has a new GM performance oil pan to clear the cross member, new motor mounts, wire harness repin and computer reprogram. I have a Boyd welding gas tank prepped for EFI ready for install. And I am building a new gauge cluster using an 96 s-10 speedo.
I thought I was all ready but then I got my latest issue of Classic Trucks and now want to install a turbo after seeing it done on 67 C10. I tried searching the forum but couldn't find much more than started projects. Anyone know of any build threads that would help. Or have any good advice?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 09-29-2015, 01:47 PM   #2
Heavymetl
Re: 5.3L Turbo Questions
Yeah, I've got a 5.3 turbo setup in my truck.
Things for a turbo build:
1) Fuel system. You're gonna need a good one capable of pumping a lot of fuel. I run E85, so I went overkill....and it works perfectly. Holley 12-1800 pump, -10an feed, -8an return, 1:1 Holley Fuel Pressure Regulator, 16 gallon Summit fuel cell. Solid fuel delivery make things great.
2) Engine management. The stock ECU "works" but mostly sucks for turbo applications. All WOT fueling is "open loop" so any sort of fuel pressure error (say, I reference line to the regulator popping off) will mean the engine dies. Aftermarket ECU's (Holley, even Microsquirt I believe) have protections.
3) Torque converter/trans. Turbo engines make bonkers torque, so you'll need a good converter for the application as well as a trans that can handle it. I'm running a 4L80E.
4) Exhaust. Run the biggest downpipe (after the turbo) you can make fit. I've got a 3.5" pipe to a 4" section with a dump. Turbos hate backpressure post-turbine. Preturbine, keep it small to spool. It's about heat energy to the turbine more than the traditional thoughts of flow.
The rest of the work is basic LS swap type of stuff. For the pipes, I flipped the truck manifolds, cut then welded a 2.5" V-band, reduced to 2", then bought a bunch of 2" piping (J bends, straights, 45s, etc) and started welding.
The results are (in my opinion) amazing. The truck idles at 650rpm, drives smooth as a stock vehicle, and pulls like a freight train on the boost. At 10psi I've been a best of 11.44@117.1, 4100lb race weight. Turbos don't need deep rear gears, I'm running a 3.25 in a 9" and have sixty foot times in the 1.63-1.65 range footbraking to 4psi. I ran Hot Rod Drag Week and averaged 11.58@116.5 for the week on low boost.
https://www.youtube.com/watch?v=8DCkwtT71E0
Buy good brakes and steering though. On 13psi my truck will spin from a 50+mph kick. I'm hoping to head back to the track soon and use 15psi, going for that 10.99.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 09-29-2015, 06:26 PM   #3
trkfrk
trkfrk's Avatar
^^^ That looks killer! Nice work! I want a turbo
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 09-29-2015, 06:47 PM   #4
68 short step
ive done a TT 5.3 in my sleeper nova..
68 short step is offline   Reply With Quote
Old 09-29-2015, 07:01 PM   #5
HSRACER
HSRACER's Avatar
Ok here is mine in a 1969 3 door sleeper suburban. I have a 5.3 with a 76mm turbo on basically a stock engine and transmission. The fuel system has been upgraded and I am only running 7 pounds of boost with a 3.07 rear end. All I can say is mama hold on when she is under load! I can't even imagine what it would be like at 10 let alone 15 psi.
This system already exceeds the suspension and braking system I have in the massive suburban. It is a great combination!
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 09-29-2015, 07:01 PM   #6
EARNHARDT#3
EARNHARDT#3's Avatar
I'd love to do this to my 2002 Tahoe when it's retired from being my daily driver. Nice turbo setup, lowered a little with some late model Tahoe 20" wheels and a fresh paint job. I already love that old Tahoe so much, can't imagine it like that!
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 09-29-2015, 07:03 PM   #7
HSRACER
HSRACER's Avatar
Here is the suburban in all its glory!
HSRACER
Slammed 53 5 window
Old 09-29-2015, 08:05 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Whatever your budget, add 30-50% for changes, incidentals, and the first few things that you'll inevitably break when adding that much power.
Find a good tuner. Not a mailorder tune. Not a "3-pulls and your done" tune. A real, logged on the street and tested on the dyno, tune.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-29-2015, 09:10 PM   #9
king-918
king-918's Avatar
Fairmont 5 build up: https://www.youtube.com/playlist?lis...QDWhnBfX_rasnJ
Here you go
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 09-30-2015, 03:27 PM   #10
Kainedogg
Kainedogg's Avatar
Great build. Can you share details on your ac setup. I plan to twin turbocharge my C10 but want to have a/c as well. I don't have room at the bottom to mount the compressor.
Science flies you to the moon; Religion flies you into buildings.
LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html
C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/
Kainedogg is offline   Reply With Quote
Old 09-30-2015, 09:01 PM   #11
HSRACER
HSRACER's Avatar
Ac is a stock LS compressor in the stock location which fits between the frame rail. Front system is vintage air and the rear is teed into the same hoses for the stock unit in the rear.
HSRACER
Slammed 53 5 window
Old 09-30-2015, 09:44 PM   #12
nsulacountry
I'll bite. Subscribed to this one!
CT
nsulacountry is offline   Reply With Quote
Old 10-02-2015, 09:19 AM   #13
matt_l
Subscribed. Great builds. I am putting a 5.3 with turbo in my 66 so this is great info.
Matt
Father Son 66 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=564694
matt_l is offline   Reply With Quote
Old 10-02-2015, 09:20 AM   #14
matt_l
What is the advantage of welding V bands on the truck manifolds vs using the flange that comes on there?
Matt
Old 10-02-2015, 11:59 AM   #15
Wasted Income
Boosted Member
Wasted Income's Avatar
Here is my turbo setup in my sleeper blazer, and the full build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=529064
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-02-2015, 01:46 PM   #16
Heavymetl
In my case, space and packaging was way easier after cutting the manifolds. Besides, V-bands don't have a gasket or place to fail and they're easy to work with. I don't even run flanges on N/A exhaust these days...
1970 C10
11.16@121.07
Old 10-02-2015, 06:28 PM   #17
aknovaman
Nevermind.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 10-02-2015, 10:31 PM   #18
69trk
69trk's Avatar
mine should be done in a couple months... in my sig....
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
