09-29-2015, 05:33 PM | #1 |
Anyone know how to remove this?
I know you remove the bolt, but I'm Having a very hard time removing this piece.
http://67-72chevytrucks.com/vboard/a...1&d=1443562280 |
09-29-2015, 05:38 PM | #2 |
Re: Anyone know how to remove this?
are you reusing the wiring harness?
They plug into each other (inside and outside) so they are probably stuck from years of corrosion. Should be able to wiggle the outside piece from the inside piece... inside piece
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
09-29-2015, 05:40 PM | #3 |
looks like the left has a bit of silicone, that might be keeping it from wiggling apart too...
09-29-2015, 05:51 PM | #4 |
It comes apart in two pieces. Just pull gently and wiggle side to side, each piece individually.
"Life is too short to drive a boring vehicle". Later, Wayne |
09-29-2015, 05:54 PM | #5 | |
09-29-2015, 06:28 PM | #6 |
I use aan old sharp putty knife to ease around the perimeter of the box a little bit at a time to loosen it up till it is free
09-29-2015, 08:04 PM | #7 | |
09-29-2015, 09:07 PM | #8 |
Once separated from the firewall push the smaller of the harnesses through the bigger of the two halves. That is how I split the wiring harness from the front lamp harness. In reverse if your holding the big part put the small part in front of the clip then pull it back towards you. It will click in to lock. jim
09-29-2015, 11:02 PM | #9 |
You are all super awesome thank you for the replies! I'll let you know of the progress tomorrow!
10-01-2015, 12:41 AM | #10 |
You guys were right there was a little silicon holding the two pieces together, I just got a flat head screwdriver, and a hammer, and very gently got the two apart. Thanks!
