Old 09-29-2015, 08:07 PM   #1
68farmfresh
68 c20 lowering kits? suggestions?
Looking to do a mild drop front and rear to my 68 c20 pickup. its a 2 wheel drive long box. any suggestions? who makes a kit for the c20 3/4 ton?
68farmfresh is offline   Reply With Quote
Old 09-30-2015, 11:49 AM   #2
68farmfresh
Re: 68 c20 lowering kits? suggestions?
bump to top
Old 09-30-2015, 12:13 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I highly suggest converting to disc brakes and using drop spindles.
They are more expensive than c10 spindles, but worth it for the stopping power.
Look at www.performanceonline.com for C20 drop spindles and other lowering components.
Keith
Convert to disc brakes.
Old 09-30-2015, 03:48 PM   #4
Tailfin57
You can use c10 lowering springs. The diameters are all the same, but your drop will be different then if installed in a c10. I suggest you go with a minimal drop spring
Tailfin57 is offline   Reply With Quote
Old 09-30-2015, 04:41 PM   #5
northerngmc
northerngmc's Avatar
68farmfresh, welcome to one of the greatest information sources online.
The forum has a great search button within each area. I suggest you try using it and you will find some great resources here.
Here are a few links you might want to look at.
C20 Lowered pictures
where are the c20 lowering parts?
There are many different routes to take. I personally wanted a small drop, 2" front and 4" rear on my 68 C20. I have hydroboost brakes that are in great condition and didn't want to swap to disks.
I bought C10 coils and replaced them earlier this month.
After replacing coils with C10 coils and shorter shocks.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
