Old 09-30-2015, 11:37 PM   #1
tdangle
tdangle's Avatar
Throttle Return Spring
OK, I just finished rebuilding my quadrajet and in cleaning things up before reinstalling on the engine, I see my dad really mickey-moused the return spring. Is it suppose to hook behind the carb or stretch to the front as he had it. Also where is the best place to find a new spring as this setup had 2 rusted complete springs and 1 broken spring.
Also the rear studs for the carb mount have the nuts frozen to them. When I removed the carb the studs came out. Replace with bolts or find new studs?
I have a stock 70 stock 350 with auto trans. The linkage is not a cable but a linkage.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 09-30-2015, 11:53 PM   #2
Gromit
Re: Throttle Return Spring
My return spring looked like this - but its a Holley 4160 not the same of course
Looks as if the spring anchor that mounts to my manifold bolt is a factory part but this is the best photo I have of it at the moment so don't know for sure..
Hope that helps - I do believe it is good to have the double springs installed in case one breaks and your throttle sticks open just as you are pulling up to the In-N-Out burger drive through line...
(please see photo attached)
Gromit is offline   Reply With Quote
Old 10-01-2015, 12:22 AM   #3
FirstOwner69
FirstOwner69's Avatar
Here are 3 pictures of my totally original 69 with a Q-Jet and 350. Unfortunately the spring is partially obscured by the TH400 kick down switch. The spring attaches at the rear to a hook on the coil bracket.
Edit: Added 3rd picture.
FirstOwner69 is offline   Reply With Quote
Old 10-01-2015, 06:27 AM   #4
hamjet
hamjet's Avatar
As far as studs, if you can't get the nut off to clean up the threads, NAPA has the studs . thats where I got mine..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 10-01-2015, 07:23 AM   #5
Mr Handy
Mr Handy's Avatar
I would definitely replace the carb studs, you should be able to get them at any parts store. Just bring the old ones to get the correct length.
The same goes for the return springs. Grab a couple different springs at the parts store and see which ones fit your setup best. I try to find a place to attach the springs to provide opposite pressure to the throttle linkage. I like the dual springs with the big outer and small inner spring. Normally there is a tab with a spring mounting point on one of the brackets for the coil or trans kick-down or another bracket on the manifold... There is also a tab on the water neck, if original, for a spring mount.
Mr Handy is offline   Reply With Quote
Old 10-01-2015, 09:59 AM   #6
tdangle
tdangle's Avatar
Thanks for the replies. I get some new studs for the back carb mounting and now know how to hook up the return spring.
Terry
Old 10-01-2015, 10:39 AM   #7
ARC190
ARC190's Avatar
I've got a bracket for the throttle cable that mounts to the back carb stud. The spring goes from throttle to that bracket. I haven't found anything short enough to replace my current spring. All the people at parts stores can't believe someone would fail to upgrade to an aftermarket. LMC's spring was even 1/2 inch too long.
ARC190 is offline   Reply With Quote
Old 10-01-2015, 11:28 AM   #8
tdangle
tdangle's Avatar
That's my next issue finding the correct spring length. And I was just thinking that since I'm going to upgrade to an HEI dust I won't be able to use the spring attachment on the coil. 70s used a linkage not a cable otherwise I'd have the bracket to attach to
Terry
Old 10-01-2015, 11:36 AM   #9
cdowns
cdowns's Avatar
I buy springs at ace hardware ame thing with studs and nuts too
Old 10-01-2015, 12:07 PM   #10
tdangle
tdangle's Avatar
Great idea cdowns! Not someplace I would have thought of.
Terry
Old 10-01-2015, 12:29 PM   #11
70's luvr
Half my truck fasteners are from Ace.
70's luvr is offline   Reply With Quote
Old 10-01-2015, 03:15 PM   #12
slikside
slikside's Avatar
This is what I used as well. Good redundancy for a critical safety item. I found mine at O'Reillys. (It had F*$% Motor Company on the package, but don't tell anyone!) Fit perfect, works good.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor.
slikside is offline   Reply With Quote
