![]() Join Date: Oct 2013
Tach information, what is this one?
Trying to identify what tach I have? Does it need a transmitter? Searched the model number and part number without any results. They are:
o Model RD-5C; and o Part No. 3771216 Mark's thread "Sun Tachometer Retrospective" was referenced to me by member MG. It has good information on GMC tachs. The Chevy and GMC tachs were manufactured by different manufactures per per information posted here, GMCs were made by Sun, Chevy not sure but possibly made by chevrolet or one of their subsidiary companies. I believe this gauge cluster with tach photos below are out of a BIG truck as it has two warning red lights below the gauges that say "Over Speed" and "Tand M Lock". Les Last edited by aotte1; 10-03-2015 at 04:39 PM. |
![]() ![]() Join Date: Apr 2012
Re: Tach information, what is this one?
3771216 shows up as a 1961 1962 tach which would need a transmitter . Only good way to tell is take the tach out and look in the side of it at the electronics. Both Chevy and GMC tachs in 60-66 were Sun tachs
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Jon,
Removed it from gauge cluster and looked inside, not much their, pointer needle attached to a coil looking devise. Will post some pictures of tach insides. Thanks for information Jon. Les |
If you decide you can't use it, put me in line for it, please.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
Photos of tach out of gauge cluster, along with last one showing transmitter model number.
Was 1963 first year they stop using the external transmitter for all truck including big and pick-ups? Note: 3852111 part number for Chevy tach W/250 or 292 from earlier thread. thanks, Les Last edited by aotte1; 10-05-2015 at 12:21 AM. |
Now if you separate the metal backing plate from the tach the Sun tag should be on the back of the tach. This tach needs a transmitter. I've never seen this style in 64 up clusters , must have been added ?
60-66
Photos of the tach removed removed below. |
![]() Join Date: Jan 2011
Yup that one uses the transmitter. Looks like it is in nice shape.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Join Date: Jan 2012
Years ago, I removed a factory tach cluster from a '62 C60 farm truck. That one had the transmitter box mounted inside the cab on the firewall. It was over on the passenger side near where the heater duct comes through the firewall. However, that's the only example of a factory installed tach I've come across in a 60-62 truck so can't say for sure that's a standard location for the transmitter box in all 60-62 trucks.
#11 | |
