Old 10-03-2015, 10:39 PM   #1
dano3
CPP bent panhard bar
Got ready to put bar on and it hits on the diff cover. I have the deluxe bracket but it seems the driver side is too far forward do I have to relocate this. My truck is a 64.
dano3 is offline   Reply With Quote
Old 10-03-2015, 10:56 PM   #2
NASTY-LSX
Re: CPP bent panhard bar
they should have told you or product should have said modifications would be or not be needed. You will need to call them Monday. Almost all there parts do not need modifications to install. Hope all works out.
NASTY-LSX is offline   Reply With Quote
Old 10-03-2015, 11:19 PM   #3
Ghernandez66
Ghernandez66's Avatar
you probably have the same problem Im having, the shop who installed the bar in my truck didn't research and used a bar that goes on the stock location but once I go too low the bar hits the diff cover. what we need is the long bar that relocates to the trailing arm I believe poterbuilt has one for like 200 bucks. good luck
Ghernandez66 is offline   Reply With Quote
Old 10-04-2015, 01:02 AM   #4
Slow Build
Slow Build's Avatar
The CPP bent bar does mount to the trailing arm. I just got mine but I haven't mounted it yet. Here's a picture and link to instructions.
http://www.classicperform.com/tech_a...-Solutions.htm
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 10-04-2015, 03:03 PM   #5
dano3
Thought I would get a pic of what I was talking about, where my hand is the side that touches the diff cover
Old 10-04-2015, 05:46 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Oh - well, that explains it.
I'm sure they couldn't account for that differential cover in their manufacturing process.
Old 10-04-2015, 06:37 PM   #7
Slow Build
Slow Build's Avatar
x2
Past GM Trucks:
Old 10-04-2015, 08:17 PM   #8
NevEno
NevEno's Avatar
The one that says fits 63-72 will not work on the 64. Unless CPP started making a bent bar for the 1964 The bracket on the frame is different. That bar only fits 65-72 without modifications.
You can find me on Instagram @neveno_cten
NevEno is offline   Reply With Quote
Old 10-04-2015, 08:21 PM   #9
The Rocknrod
Moderator
Bracket on the frame, please explain.
I'm hoping O'l Slow Build will discuss this when he installs it on his 64. Then I will buy one - or not.
Old 10-04-2015, 08:35 PM   #10
NevEno
NevEno's Avatar
This is the pan hard bar mount on my 65.
Old 10-04-2015, 08:36 PM   #11
NevEno
NevEno's Avatar
This is the pan hard bar mount on my 64.
Old 10-04-2015, 08:46 PM   #12
Slow Build
Slow Build's Avatar
My 64 is sitting on a 65 frame so my driver side bracket will be slightly different. Also I won't be mounting it for a little while. I have a few other things to do before I get to the rear suspension.
Dano, what rear end do you have in your truck? Judging by the original panhard mount location on the diff it's at least a 65. You might have to go with a short adjustable panhard bar to that location instead of relocating to the trailing arm.
Past GM Trucks:
Old 10-04-2015, 09:14 PM   #13
dano3
Its from a 71 c10
Old 10-04-2015, 11:40 PM   #14
The Rocknrod
Moderator
I am missing something still on why it wont fit. Length?
http://www.classicperform.com/Store/...ck/CP32021.htm
Old 10-05-2015, 12:20 AM   #15
russellrox
is there any way to adapt the stock panhard bar to make this work, my diff is the same as this one with the stud mounted to the top right of the diff housing, my truck is a 66 c20 that is converted to a c10 with the 71 rear diff. I was wondering if there is a place to find a oscilating ball mount so I could weld one on so the bar doesn't have to be bent to mount in the stock location. My truck is a 66 btw.
russellrox is offline   Reply With Quote
Old 10-05-2015, 10:55 AM   #16
chevy_mike
Never Ending Projects
chevy_mike's Avatar
IIRC, the CPP bent style bar was made to clear a Ford 9" housing. It was not made originally to clear aftermarket diff covers for the stock 12 bolt. That said, most aftermarket panhard bars won't clear the diff covers that have the bearing cap supports, regardless of who make them.
Problem is not the bar, it's the diff cover.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-05-2015, 10:21 PM   #17
dano3
But I still have to push bar towards the cover to get it in the mounting place, so the bar is not at the right angle. I hope this made sense, so I might move mount to where the bar is not bound up.
Old 10-05-2015, 11:30 PM   #18
Slow Build
Slow Build's Avatar
Can you show more pictures of the whole bar and brackets installed? It's kinda hard to tell what's going on from just one picture.
Past GM Trucks:
Old 10-06-2015, 05:34 AM   #19
The Rocknrod
Moderator
Or you could change the diff cover and it will fit. Or not.
Old 10-06-2015, 11:08 AM   #20
chevy_mike
chevy_mike's Avatar
How much are you having to push the bar? 1/2" or less, that is likely production variances.
Old 10-06-2015, 06:43 PM   #21
dano3
I took these pics of the bar where it wants to go, where the bracket is how much I have to push it in place but wont of diff cover. As you can see if I went this route it would miss the diff cover.
Old 10-06-2015, 09:34 PM   #22
NevEno
NevEno's Avatar
I've already spoke with CPP about this issue and they agreed that it won't work.. The bent bar only works on 65-72 because the frame mount on the 63 and 64 are different. see above pictures. It may be hard to tell but the angles are different. I ended up giving mine to a buddy and ordered a Porter Built trac-bar. You can move the frame mount. Hope this helps
Old 07-30-2016, 07:54 PM   #23
crakarjax
crakarjax's Avatar
I've got that same panhard mount on my 68 3/4t longbed... looks like I'm going to have to relocate the bracket based on the feedback here.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 07-30-2016, 09:05 PM   #24
The Rocknrod
Moderator
Thats why I changed my frame bracket for the panhard bar to a 65. Sits right where it needs to be.
Old 07-30-2016, 09:53 PM   #25
NevEno
NevEno's Avatar
Hope this helps
1963-1964
65-72
The CPP bent bar works in this location
