Old 10-03-2015, 11:41 PM   #1
91rcsb
'71 c30 hanger/shackle
Could I have you guys take a look at my poor quality pictures and see if you think the standard drop hanger/shackle kits for 67-87 leaf sprung trucks would fit? I recently removed the deck and am not sure what I will be doing for a box but would like to tackle the suspension. I intend on removing the overload leafs and the truck also had lift blocks in.
91rcsb is offline   Reply With Quote
Old 10-04-2015, 09:31 AM   #2
Mike C
Mike C's Avatar
Re: '71 c30 hanger/shackle
The 2x4 67-72 trucks had 2 1/4" wide leaf springs at least on the 1/2 and 3/4 ton models. What is the width of your spring? If it's 2 1/4" then the ECE shackles will work. If it is 2 1/2" most likely the '73-'87 would work just fine.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-04-2015, 10:12 AM   #3
hugger6933
When the 88 body style came out the local muffler shop would take those shackles out and cut them in half and weld plates to each side making a drop shackle. Just a thought. Jim
hugger6933 is offline   Reply With Quote
