Old 10-04-2015, 09:13 PM   #1
wkclifton4
headers on a 1968
i want to put long tube headers on my 1968 chevy c10 but i noticed that the alternator mounts on to the factory ram horn on the left side of the engine what do i have to do to install the long tubes thanks for your advice
wkclifton4 is offline   Reply With Quote
Old 10-05-2015, 02:50 AM   #2
12secondnova
12secondnova's Avatar
For everthing else ive had long tubes on they come with a little spacer for it. These were hooker super comps so i cant speak for all brands though.
12secondnova is offline   Reply With Quote
Old 10-05-2015, 12:50 PM   #3
cooperhw
cooperhw's Avatar
Re: headers on a 1968
I put headers on my 68 and cut a small piece of pipe between the header flange and the bracket on for the alternator, then used a longer bolt.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 10-05-2015, 01:45 PM   #4
LJ Legnon
LJ Legnon's Avatar
Can you provide me with an e-mail address to send hi res pictures to? I tried to attach, but can't due to size. I have a '68 350CID, with Headman Headers, it appears that the mounting bracket might be different? I purchased it this way, so can't help with the part unfortunately.
LJ Legnon is offline   Reply With Quote
Old 10-05-2015, 08:59 PM   #5
BCOWANWHEELS
I,d install a set of corvette 2 1/2" outlet rams horn manifolds instead, dorman makes cheap repops . all headers leak,rust out quickly and super heat the floor board up. jmo
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
