Old 10-05-2015, 12:34 PM   #1
Myoldtruck
Myoldtruck's Avatar
Proper crossmember for sm465 2spd 2wd
I currently have a 1970 c/10 with 350/3spd on the floor. The sincros on 3rd gear are going bad. I picked up a sm465 that was originaly in a 1970 c/20. I got the bell housing and floor pan for it also.
The 3spd trans is using a standard type cross member at the rear of the trans. The sm465 doesnt have any thing on the rear of the trans for a rubber mount. Im assuming their is another way the bell housing mounts for support closer to the engine. Any input or pictures would be a big help.
Myoldtruck is offline   Reply With Quote
Old 10-05-2015, 01:36 PM   #2
ak808
Re: Proper crossmember for sm465 2spd 2wd
I know its not the best picture.... but here is a 70 c20 with a sm465. Stock crossmember as far as I know.
ak808 is offline   Reply With Quote
Old 10-05-2015, 02:59 PM   #3
cleszkie
cleszkie's Avatar
You will need the bellhousing cross member to support the SM 465 in a 2WD truck. The bellhousing cross member bolts directly to the bellhousing with two rubber mounts. See attached pictures.
cleszkie is offline   Reply With Quote
