Old 10-05-2015, 04:43 PM   #1
daveklein
Carb linkage
I just got this 67 and even I know this ain't quite right...What is the correct linkage and better yet,,,Where can I get the pieces I need...Does anyone have a pic of the correct linkage ??? Also is the carb the correct?? Thanks for the help...Dave
I hope I did the right thing and the pics will be here.............
Is that the correct radiator ? Should it have an overflow tank?
daveklein is offline   Reply With Quote
Old 10-05-2015, 05:02 PM   #2
bill3rail
bill3rail's Avatar
Re: Carb linkage
As far as the carb goes, I'll leave that up to the pros here.
The linkage, is factory coat hanger linkage, don't mess with it, you'll never get it the same again! J/K
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 10-05-2015, 05:07 PM   #3
daveklein
Re: Carb linkage
Hey Bill...Can you send me a pic of your linkage??? It must be the same as what I need.. Dave
Old 10-05-2015, 05:35 PM   #4
michael bustamante
michael bustamante's Avatar
Re: Carb linkage
it s looks right to me...hahahahaha
no theres a rod that hooks up there, im sure one of the guys on here has one for you
1967custom
michael bustamante is offline   Reply With Quote
Old 10-05-2015, 06:00 PM   #5
trac209
Re: Carb linkage
No that's not the right carb for sure
trac209 is offline   Reply With Quote
Old 10-05-2015, 06:42 PM   #6
michael bustamante
Re: Carb linkage
correct rad and no, no overflow tank
oh yeah it looks like the carb is mounted different.
1967custom
Old 10-05-2015, 06:47 PM   #7
daveklein
Re: Carb linkage
OK you guys...I know there are 1000's of you that have taken that old 6 cyl. out and put in a V-8.....I need the carb and linkage that you saved..Let me know and I'LL buy that from ya....Send me a PM or call me at 863-273-1907.
Thanks...Dave in FL.
Old 10-05-2015, 07:19 PM   #8
trac209
Re: Carb linkage
The stock link is a solid rod . A proper carb can use a plain solid rod you can bend up yourself. So all you'll need is the carb really.
Old 10-05-2015, 07:59 PM   #9
daveklein
Re: Carb linkage
OK great...Now I just need to know what is the correct carb that belongs on it..
And there is some sort of fulcrum deally just behind the carb mounted to the manifold that seems like it may have something to do with the linkage...
Dave
Old 10-05-2015, 08:26 PM   #10
EARNHARDT#3
EARNHARDT#3's Avatar
Re: Carb linkage
I have no idea what kind of carb that is. But I'll bet it works better than the Rochester B that would've came on your '67!
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
