aluminum radiator question
I recently purchased an aluminum radiator and I missed some really fine print that it is only a direct replacement for a manual transmission. The seller said: If you have an auto transmission, you would need to modify and re-tap the ports and get the fittings separately. Also, another option is to get an external TOC. I don't under this. My transmission lines fit into the ports fine. Will it not fit because it doesn't have an internal transmission cooling box? What are transmission line ports on it for then? Thanks.
![]() Join Date: May 2014
Re: aluminum radiator question
If your lines fit the ports then it's not an issue. They wouldn't be there if it didn't have a built in trans cooler.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
Can you post pics?
#4 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Pic
I am away and won't be able to hook up a hose to it. Why would the ports be there if it isn't for the transmission cooler? I am all mixed up now.
Looks like it has a cooler in it. I would try blowing some air through the welded on bungs(fittings)
Old member
It looks like it's all there. Can you see it from the cap looking inside the radiator?
Stupid question, but what would it look like?
Ok, I just went out and blew air in the bottom fitting, and it came out the top. So, I guess it has a cooler in it. I still don't understand what the seller was talking about. Anyone see a reason why I couldn't use this radiator on my truck? Thanks
(((I still don't understand what the seller was talking about)))) he probably does'nt either. looking down through the radiator cap hole you will see a coil tubing going from top fitting to bottom fitting, also by blowing air like you did, if you put your finger over the other hole you should have pressure build-up.
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
#12 | |
Old member
![]() Quote:
#13 |
It does build up pressure when I cover the top hole up and blow air in the bottom one. I checked the inside of it compared to the old one and they look the same. They both have a piece of tubing running from one hole to the other. Hard to see from the picture. Thanks for the responses, I really don't want to burn up my transmission. I don't have a temperature gauge on it.
#14 |
He probably has no idea what comes in the box he gets from China. He's just assuming it has no trans cooler.
#15 |
You have a built in trans cooler no doubting that now,but an auxiliary one is still a good idea if your truck will see some work or harder style driving.
#16 | |
With the cooler being built-in, it's just like saying you don't want to use the radiator in fear of burning up your motor. I know it was a gauge but that cooler is there so it can work, just like the radiator is. I am looking for a manual radiator, if you want to see it drop me a PM (include the outside diameter of radiator and thickness). Thanks |
#17 |
This is the last response I got from the seller about it being a manual transmission only radiator: Hello,
Thank you for your reply. The way these radiators are manufactured are for manual transmissions. However, as you can see, there are ports on the right side for this radiator for automatic lines, meaning you can convert this manual radiator to an automatic radiator. The radiator already has a internal transmission cooler, but to be able to convert this manual transmission radiator to an automatic, we strongly suggest that if you are going to do this conversion, that you speak to a local shop or technician, to be able to avoid technical issue and receive the proper guidance on what will be needed to be done. What would need to be done to convert this to an automatic one? I don't see any difference between the old one and the new one. Hopefully I am just over worrying about this. Thanks |
#18 |
![]() Join Date: Jul 2015
you're over thinking it and they are covering their own ass. Pretty much they say that so you don't screw the wrong fitting in and say it's damaged and the part they sold you caused a failure. If your lines fit and don't leak go for it. Double check that you don't need an NPT to flair adapter on the new radiator.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
#19 |
I spent some time test fitting today. It fits really well. I got the electric fans installed and got the relay system mapped out of where I am going to wire everything. The new core support fits perfectly too. I will finish wiring it up in a few days and be ready to reinstall the grille. I went with a derale 16749 relay kit, but decided to go with a different temperature sender. I am going to use the one that is just inserted into the radiator fins. Thanks for the help.
#20 |
Your fans will cool much better if a shroud is used. That way the air drawn through the radiator will pass through all the radiator in stead of just the fan area.
Russ
RC |
#21 | |
X2 you're going to be leaps and bounds ahead in cooling ability if you have a shroud.
#22 |
I have 2 temperature probes, one that is threaded and one that is inserted into the radiator fins. I want to run the temperature probe for the fan relay in the radiator and not the intake or heads. My threaded port on my radiator is 1/8 and my threaded port is 3/8. I bought an adapter to fit the 3/8 probe into the 1/8 port, but am concerned about it getting an accurate reading with the adapter on it. Anyone else ram an adapter like this?
#23 |
Simple test. Get a piece of rubber tubing, insert it into one of the transmission ports and blow air from your compressor into that port. If air escapes only through the other port there is a built in trans cooler in your RAD and, since manual boxes don't have fluid pumps, your RAD is built for an automatic!
#24 | |
#25 |
This is the way I understand it, I may be wrong, but this is what I have gathered from the forum here. The thermostat in the water neck let's the coolant in when the truck gets hot. The temp sensor for the fans needs to come on when the coolant is over a certain temperature to cool down the coolant in the radiator. If you put the temperature sender for the fans in the head, the fans could be coming on when the motor is over temp, but the temp of the coolant may be already cooler. The thermostat and coolant cools the motor, the fans and radiator cool the coolant. I would want the fans to come on when the coolant is over temperature to be able to cool the motor when it flows through the thermostat in the motor. I am not a mechanic and have a thimble full of knowledge on the subject, but that is the way I understand it. I think it mostly evens out once the motor heats up anyway and the fans will be running most of the time anyway.
