Is it a '71 C30?
I recently purchased a 71' C30. Rough condition but I do have plans. Being my first 67-72 I have been doing a bunch of research and am questions parts of the truck. The grille, cab lights, mirror base seem to be that of an earlier model? I will attach pictures for reference. The truck's SPID is missing. The Canadian vin has me going between a '71 or '69 depending how you look at it.
![]() ![]() ![]() ![]() ![]() Last edited by 91rcsb; 10-08-2015 at 12:17 AM. |
Re: Is it a '71 C30?
Not sure on year but looks like a work horse. Love the bugshield...awesome! Good luck with the build.
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
![]() Join Date: Jan 2002
Hockey puck cab lights were 69 only. Mirrors look like 71-72 sport mirror bases with camper mirror heads
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
I'll play
Rear view mirror says 72. Are there screws in the doors near the wing vent? Another 72 only. |
![]() Join Date: Nov 2006
I bought a c-30 with longest wb gm made a while back, plans are 14 bolt (daully) wide rear end, 1982 front x-member with all suspension (dually also) air ride rear suspension, 427 td or dodge 6bt ( I have both and cant make up my mind ) th400 or nv4500 ( I have both of these too ) custom 10 ft aluminum flat bed . sure beats 60-70 k for a new truck.
I BELIEVE IN JOHN 3:16 |
![]() Join Date: Mar 2003
Disc or drum brake on the front?
I dig the "Mad Max" front bumper!
its a 1971 or 72 so I,s say disc. want me to check tomarrow
??? Wasnt the 72 mirror mounted to the windshield? I say 69-70 cab.
"You can take the man out of PA, but you can't take PA out of the man" |
Clearance lamps, grille, drum brakes, and VIN-plate say '69. The lower plate has been removed. What type of gas pedal does it have, off the floor w/rod linkage or hung off the firewall w/cable? Looks to me like doors were replaced or mirrors changed. But who would put car mirrors on a C/30 work truck? My bet is doors changed
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
If you really want the lo down on the truck, contact the GM Heritage centre and for 50/75.00 they will send you the trucks history with options and first owner info.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Additional info. The owners manual I found in the truck was for '71, the puck style cab lights have the number '69 on them, insurance and registration said '71 but they had the S digit down as a 5 so I am not sure how they found it in the system, front drum brakes with 1/2" studs, the gas pedal was broke off but I believe it was hinged at the floor, throttle linkage is rod not cable.
#13 |
#14 |
#15 | |
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#16 |
![]() Join Date: Sep 2007
well they look like rosette rivets so the tag has not been removed. and that carrot magnet is a 71 only option.......
1967custom |
#17 | |
Your VIN plate says 1969 C = 2wd 9 = Denotes GMC S = 6cyl 3 = 1 Ton 3 = Cab and Chassis 9 = year = 1969 1 = assembly plant = Oshawa, Canada 105231 = unique sequence number = #5231 assigned/built, in 1969 Model Year @ Oshawa
CHEVY/GMC VIN DECODERS |
