10-08-2015, 04:25 PM | #1 |
My son's first truck
Hey guys, I have been looking on here for a while and have picked up a lot of great info.
i just bought my son his fist truck. 67 C-10. It has a front end from a 69 and a cedar wood bed. 292 w/3 on the tree. We were considering ordering some kick panel speakers from LMC, was wondering if anyone on here had any experience with these (item #38-8520) or any others. Any input would be appreciated. Mandatory pics... |
10-08-2015, 04:43 PM | #2 |
Re: My son's first truck
Diggin the wood dash. Not just plastic overlay, but the real deal!
Sorry, can't help with the kick panel speakers... I just went in the doors.
68 C10 SSB 383 12 Charger 6.4L 12 Accord 3.5L (Wife's ride) 05 Ram 1500 5.7L My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545 |
10-08-2015, 05:17 PM | #3 |
I have them on my 70. They work and fit good. Only thing I had to do was move my High/low beam switch over just a bit. Other than that, no issues.
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
10-08-2015, 05:21 PM | #4 |
theyre only held in by the door weatherstrip. not very sturdy i had to run two short sheet metal screws to secure it to the kick panal. it barely clears the e brake pull handle if you mount a grill on it
1967custom |
10-08-2015, 07:35 PM | #5 |
The E brake shant be a problem on his truck it is a 67 the e-brake is on a handle under the dash cluster.
10-08-2015, 08:35 PM | #6 |
You can fit SO MANY CHICKS in the back of that thing!!! Lucky guy!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
10-08-2015, 09:49 PM | #7 |
10-09-2015, 08:13 AM | #8 |
I installed plastic kick panels in my truck. They were too shallow to mount a good quality speaker so I made a ring out of 1/2" board to provide a bit more clearance. Then a sawed out a backing board so that I could seal the kick panel from behind. I stuffed a bit of insulation into the kick panel cavity and then glued the plastic kick panel to the backing board using silicone sealer. Finally, I got several stick-on felt "dots" to the back of the panel so that it wouldn't rattle once attached to the metal kick panel. One small hole was drilled and a single screw was used to secure the kick panel assembly in place. I am getting a decent bass response out of these 6" speakers now.
