1966 K10 SWB Sepside Goldie
Well here we go...
Bought the truck about a month ago from a gentleman who said he found it beside a chicken coop, buried in chicken sh*t and dirt. He spent some time on it cleaning it up a bit. Then put new brakes and exhaust. Elderbrock mainifold and carb. He then added the rally wheels and HEI. So some of the stock stuff is gone but seems to be pretty good shape except the normal rust areas. It runs great, I have put about 500 miles on it running around. Note the horse trailer behind it. ( Daughters wedding set up and dismantle hauling stuff with Goldie) Odometer reads 79XXX miles on it which he was told are actual miles has not been rolled over. Now what.. I think I will do a frame off and mechanical rebuild nothing wild just stock and seal it up and get rid of the rust and preserve it. Lots of inperation and information here I know I will need it. A thank you to Captainfab for the once over on the truck, I sure I wil be using that valuable resource. Anyway here is some current photographs before I start the tear down, I keep putting it off I love driving the truck...
KippnIdaho Twin Lakes, Idaho 1966 K10 SWB Stepside 2003 Jeep Rubicon 2011 Camaro SS Rag Top |
Post Whore
![]() Join Date: Mar 2013
Re: 1966 K10 SWB Sepside Goldie
Good looking truck! Does it have an original 283 or 327?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
I believe it to be the original 283 4 speed 373 gears I think. only time will tell for sure
Post Whore
Those are a darn good engine.
![]() Join Date: Aug 2008
Very nice. Drive it as long as possible
Nice! I like a short step 4x4!
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
60-66 Nut
![]() ![]() Join Date: Mar 2007
It's good to see you start a build thread Kipp
Welcome.
Very nice truck. And as mentioned, keep driving it.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
Welcome to the 60-66 K10 club. Not many originals / stock around, so there are only a few.
'62 Chevy K10 |
I guess I need spell check.
Nice tk Kipp--looking forward to the build--have fun!
1961 chevy K10 my build is------------61K10 build |
#12 | |
Mike 1972 C10 Cheyenne SWB Black Supercharged Project 1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175 1969 Camaro Protouring LS7 T-56 Project |
#13 |
I have this stamped on the passenger side block in front of the head. I thought this was supposed to be the VIN.
Any help?
#14 |
Well thanks again to Capt. Fab for hooking me up with a great meter guy. So I have started the dismantling of Goldie.
Anybody have any info on the the prior post these numbers are stamped on the front passenger side of the block. Pictures to follow. I also need to learn about gearing change 373 to 308. Are the ring and pinion gears the same for the front and rear dif. Thanks
#15 |
No spell check not a meter guy a metal guy.
#16 |
![]() Join Date: Dec 2014
Stamping is engine code, not all engines got a vin, I am more familiar with corvette codes, and someone with a book handy will probably do better but this is what I think your stamp breaks down to
V=Flint Michigan plant 04= 4th month April I0= I think they used I in place of 1 to differentiate from L, so I think this is 10th day WO is suffix for 283 manual trans, 2 bbl 175hp k10/k20 in 1967 (makes most sense for your truck, but is also a 307 in 1968, and 350 in 1969 If it still uses a canister type oil filter you can bet its an earlier 283, but it could easily had a spin on adapter added over the years |
#17 |
Kool truck nice looking original good to see your using it, I've heard a lot of people over the yrs say that they enjoyed there trucks a lot before they restored them. And now there afraid of scratching them up. Of course I can't blame them after that especially with a wooden bed floor who would want to tear one up after it's nicely done...I'll be watching progress...
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#18 | |
60-66 Nut
Glad to hear that Rob is going to be able to get your metal work done.
To change your 12 bolt to 3.07 gears, you will need a different carrier. I'm not sure on the Dana 44 but I don't think you'll need to change the carrier. The truck 12 bolt and Dana 44 gears are not interchangeable. I believe I do have a disc brake Dana 44 with 3.07 gears if you are interested. Quote:
#19 |
Thanks John.
I will get with you on the gear change. And an update Front clip, in pieces, went to the metal guy, so it now begins......
#20 |
Good looking Truck! What are your plans with it? Love to see your progress as I am also doing a 1964 k10!
1964 Chevy Factory K10 Short Bed Mitchell Sampson |
#21 |
Doing the tearing apart now, front clip is now with the the body guy, kind of doing the body work one piece at a time. Bed has been removed next is the cab. While the body is off I will go through the running gear. Going to try to keep it stock. It will be a fun winter project
#22 |
Do you know what color your doing yet?
#23 |
It is currently a gold color I think it's called saddle color code 525. I am not sure on the interior it has the fawn with a brown dash and grey glove box and radio delete.
I need to research the interior and see if the current color combination is stock if it is I would like to keep it that way. Like I have stated before I want to keep it as stock as possible, except for the gearing. I would like to change those to a more highway friendly ratio.
#24 |
where are the pixs we need pixs I need more pixs.. LOL, Glad to here that your working on it...
#25 |
Here is the picture of the interior. Trying to determine if it is stock.
