10-12-2015, 08:11 PM | #1 |
what's a good welder to weld patch panels
I like a miller found a miller 210 at a good deal is it to big
10-12-2015, 08:12 PM | #2 |
Re: what's a good welder to weld patch panels
Fount a miller 210 I think it mite be to big
10-12-2015, 08:24 PM | #3 |
I got a Hobart 190 mig with a spool gun kit. I payed $850 free shipping a yr ago from cyberweld. A little 120v will do panels but I needed something bigger to do frames. if you're going mig that is and u need to buy the tank and gas.. because flux is no good for panel work imo.. iv heard good things from lincon welders for starters i never ran one thowe.
10-12-2015, 08:27 PM | #4 |
second the Miller. Millermatic Auto-set 211 is my go to.
10-12-2015, 08:27 PM | #5 |
You will want a welder that will run .023 size wire for sheet metal to minimize warping
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
10-12-2015, 08:29 PM | #6 |
10-12-2015, 08:39 PM | #7 |
Looked at miller 211 they change it a lot look smaller
10-12-2015, 08:50 PM | #8 |
Miller is good quality but like anything else, it could be used and abused. Ive worked in some production shops that ran 3 shifts so those machines were well worn. If it came from some guy who didn't use it much and the price is right, snag it. I paid $1200 for my millermatic 210 back in '04 and it has maybe an hour use on it, lol. They don't even make that model anymore. Ive used lincoln and esab. Both good also.
10-12-2015, 08:59 PM | #9 |
What's the smallest wire you can use on the 210
10-12-2015, 09:09 PM | #10 |
The 210 accepts the following drive rolls:
V-Grooved Drive Roll Kits and PNs (solid wire) #204 579 .030 & .035 in (0.8 & 0.9 mm) Combination (Reversible) #087 131 .023/.025 in (0.6 mm) #079 594 .030 in (0.8 mm) #079 595 .035 in (0.9 mm) V-Knurled Drive Roll Kits Since it accepts and uses the 0.023 drive rolls it will use 0.023 wire which is good down to 22 Ga sheetmetal. |
10-12-2015, 09:30 PM | #11 |
I've found a miller 211and 210 the difference is 300 dollars
10-12-2015, 10:02 PM | #12 |
fellas: if it counts for anything I managed to do all my patch panels and a large portion of the floor with a hobart handler 175 mig welder with gas.And i managed to teach myself to mig weld with it also. I do wish it was a Hobart handler 125. it would have been nice to have a bit lower heat setting. Most people that have seen my welding think it looks pretty good. Patience and take your time young grasshopper,you can do it. Just say'in
1970 3/4 ton long box GMC !968 C10 short stepside (Papa's Old Lorry) 2006 2500 HD Silverado Duramax/Alison |
10-13-2015, 07:15 AM | #13 |
I'm still using the Snap-On welder I bought in 1988. I don't think they make it anymorebut is a ya240 it is a big machine and it has been real good for me.
10-13-2015, 07:52 AM | #14 |
I like the small Lincoln line. Currently have a Lincoln 140 with a gas kit. It works very well for most projects that I have tackled. This includes building roll cages and welding sheet metal.
10-13-2015, 12:01 PM | #15 |
I have a Miller 140 Auto-set and a 211 Auto-set. The 140 is the one I use on sheet metal. It's just easier to use the 140 for light stuff and the 211 for general heavy welding.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
10-13-2015, 12:03 PM | #16 | |||
"I ain't nobody, dork."
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
10-13-2015, 12:06 PM | #17 |
Thanks everyone for the help
10-13-2015, 12:19 PM | #18 |
I know if mine crapped out I would look for something besides the kind I have now I paid 3200 for mine in 1988 wouldn't that be like 8000 dollars in todays money? I am sure the ch is leaps ahaed of what my was but it still welds and I have only had to have it worked on once I did replace the liner and gun with a flex one if you don't have the swans neck look into them their the bees knees.
10-13-2015, 12:20 PM | #19 |
But I also paid like $2000 for my plasma cutter that never worked right and the $750 avortec I replaced it with is ten times better.
10-13-2015, 04:09 PM | #20 | |
10-13-2015, 10:50 PM | #21 |
thanks you for that info. I was always curious about why I was always geting there tips and drive rolls when I order... now I know.
10-13-2015, 10:58 PM | #22 |
I bought a used millermatic 140. 400 dollars. Using .023 wire to do sheet metal work. Works great . Use .030 for heavy stuff. Really a good set up. You can see the results in my build thread The Mother Trucker.
10-13-2015, 11:09 PM | #23 |
I have a millermatic 210. Went under salt water in huricane ike. Washed it out. Put new liner and wire. Still working to this day. In my opinion i like the millers the best out of wire feeds. Used plenty of others but the miller seems the smothest to me.
52 Chevy 6400, 1 ton dually 4x4 350 vortec NV4500 315/75-16 tires http://67-72chevytrucks.com/vboard/s...d.php?t=661795 94 Chevy K1500 4.3 4l60e (The Wifes) |
10-13-2015, 11:58 PM | #24 |
today most welding machine are made well , if you are not doing structural any 110 v welder is fine , but as mentioned you want the option to run gas and also the option to run 0.23 wire for tin panel work ,
if you are not experienced with welding I would opt for 0.23 silicon / bronze wire . it is soft and flows nicely so your panel work will not heat up as much and will make warping minimal = less body work I prefer and weld body panels with a Tig , but Tig welders are costly |
10-14-2015, 12:08 AM | #25 | |
