Old 10-13-2015, 04:10 PM   #1
CastIron
CastIron's Avatar
How are you guys running your HEI wiring?
I'm replacing my original 307 with a new 350 on my '69 C1500 and making some other mods at the same time. I'm installing a new HEI distributor. My plan is to remove the original resistor wire from the bulkhead connector and run a new wire from the same position on the connector directly to the distributor. Is anybody else doing it this way?
When tracing the original wiring it appears that the resistor wire runs down the harness to near the starter, then splices into the yellow wire that runs between the starter solenoid and the original coil. I plan on removing this.
On a slightly different subject, I'm adding an electric choke carburetor. I haven't figured where to run it that wire from, but I'm planning on checking to see if there's any empty places on the bulkhead connector that have power when switched on. Anybody have connector face diagrams that show what wire goes where?
What do you guys think? My goal is to have a clean-looking, reliable engine harness.
CastIron is offline   Reply With Quote
Old 10-13-2015, 04:22 PM   #2
lts70
1970 Daily Driver
lts70's Avatar
Re: How are you guys running your HEI wiring?
http://67-72chevytrucks.com/vboard/s...d.php?t=553330
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 10-13-2015, 04:28 PM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
That is how I did mine, just replace the resistor wire with at least a 12 gauge wire and you will be good to go. I forget where I connected the wire for my electric choke. I believe there is a 20 gauge brown wire with a white stripe that had a female Packard 56 end on it that terminated in the cowl wiring gutter that I used. I can look after work and let you know on that.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 10-13-2015, 04:31 PM   #4
Davidf
When I purchased my truck, the engine wiring harness was a hacked up mess. So, I purchased a replacement engine harness from one of the major vendors. The harness was specifically prepared for HEI distributor. Killed two birds with one stone.
Davidf is offline   Reply With Quote
Old 10-13-2015, 04:50 PM   #5
leftybass209
leftybass209's Avatar
I ran a new wire from the bulkhead as well. I later switched to an m&h harness that already had it done, but same thing.
I ran my choke wire from the Transmission spark control wire which should have a terminal in the wire gutter, but I can't remember what year trucks had it. You can run a wire from an ignition unfused terminal on your fuse block with the appropriate Inline fuse.
I'd say your doing it the smart way, instead of splicing and pulling from other circuits.
leftybass209 is offline   Reply With Quote
Old 10-13-2015, 04:53 PM   #6
beaterku
beaterku's Avatar
I created a new relayed circuit for my HEI. I used the original resister circuit, minus the resister, to trigger a relayed power source directly from the battery.
beaterku is offline   Reply With Quote
Old 10-13-2015, 04:53 PM   #7
michael bustamante
michael bustamante's Avatar
i ran a 12 gauge thru the firewall next to the hei and down to the ign open space on the fusebox
1967custom
michael bustamante is offline   Reply With Quote
Old 10-13-2015, 04:54 PM   #8
Fitz
Those of us with working ignitions wired them up as the manufacturer recommends in their wiring diagrams.
Fitz is offline   Reply With Quote
Old 10-13-2015, 05:22 PM   #9
hamjet
hamjet's Avatar
I pulled the bulkhead apart, replaced the resister wire with 12 ga. wire to the dizzy. at the dizzy where you would put a connector to plug in, I used a larger ga. connector and slipped both the 12 and a 14 ga. wire together to go to the electric choke.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 10-13-2015, 07:00 PM   #10
midniteblues
midniteblues's Avatar
i had a couple butchered harness's layin around so i pulled the big red power wire with the terminal out of the bulkhead.
then on a jy trip i got the oe hei plug with the longest red wire i could find. then soldered it together in the gutter.
plugged it right back in where the original resistor wire was.
while at the jy i also grabbed the correct connector that fit in the tac location on the hei.
they work better and wont fall out like a cheap female spade connector.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 10-13-2015, 07:20 PM   #11
wreckedchevy
wreckedchevy's Avatar
mine's feed off the keyed hot on the starter 22years with no issues so far
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 10-13-2015, 08:41 PM   #12
EARNHARDT#3
EARNHARDT#3's Avatar
Just remove the resistor wire and replace with a 12 gauge wire. The bulkhead terminal connectors are readily available. Unwrap your harness, swap wires, wrap it back up. Takes about an hour.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 10-14-2015, 10:51 PM   #13
CastIron
CastIron's Avatar
I just need the terminal to plug into the bulkhead connector and I'm good on the ignition circuit. It doesn't sound like anybody's had a problem doing that way.
For those of you with electric chokes, where are you running the power wire from? I did a quick check earlier today and it doesn't look like there's any extra switched power terminals in the fuse block that go to the engine harness. I did convert my 10DN alternator to a 10SI, so I'll look in that area and see if I can wire something up along the forward lamp/generator harness. I will have to look at a wiring diagram and try to find something.
Old 10-15-2015, 08:04 AM   #14
70STOVEBOLT
I remember what I did for my choke now. I used an ignition unfused terminal on the fuse block and put an inline fuse between that and the interior side of the bulkhead connector.
Then I ran a wire from the same position on the engine side bulkhead connector to the electric choke. Made for a clean engine compartment installation. I don't know if I really need the inline fuse but I read on the forum somewhere (Electrical section I think) that is what someone suggested.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 10-15-2015, 04:56 PM   #15
dirtyjim
dirtyjim's Avatar
just order pn 60-132046 from from truckandcarshop.com for $6
hei lead wire with a Packard 56 terminal on one end and hei connector on the other, I have the terminals and wire and would break even making them at that price
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
