10-17-2015, 02:57 PM | #1 |
Dodge Dakota door seals not even close.
I ordered a new set from Rock Auto. They went on nice but, I cant even get the door close to closing. I ordered them for a 1992. Are used ones the only way to go? All the ones in the junkyard I've ran into were worn out by the door sill from boots.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
10-17-2015, 03:05 PM | #2 |
Moderator
Re: Dodge Dakota door seals not even close.
I've pulled several sets from junkyard trucks and have not had a problem. I think the key is that they are 25 plus years old and broken in. The ones on my 68 work perfectly, door closes nice and tight but does not need to be slammed. Based on all the threads here that I have read it is a crap shoot as to how clip on type door seals will fit an individual truck.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
10-17-2015, 07:11 PM | #3 |
I thought i read in a different thread a while back that you may have to slightly bend the mounting lip inward to use the dakota seals, but don't quite me on that.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
10-17-2015, 09:19 PM | #4 |
I have used 1985 dodge truck seal.They fit need just need to adjust the pinch weld.
10-17-2015, 09:27 PM | #5 |
Wes from Classic Heartbeat sells some clip on ones. I don't know how they work but I plan on buying some when I get to that point. I thought this could be useful information in the future.
10-18-2015, 12:55 AM | #6 |
Ended up going to the wrecking yard and grabbing used ones. They fit much better. I will run them until I find some nice used ones. Didn't want to mess with my pinch welds or door adjustment.
