Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 10-17-2015, 09:10 PM   #1
konajoe
konajoe's Avatar
71 Trazer 4x4 Project
Starting on a new project, picked up this 1971 pickup today. While searching around for a decent 73-87 cab to build as a trail rig I stumbled across this 71 C10 cab mounted on a 69-72 K5 Blazer chassis. It has the usual rocker and cab corner rot, the modified bed is pretty shot on the inside, but overall the truck is in decent shape for the year especially being from New England.
Build plans are...
Dana 60 front
Dana 70u rear
Small block
465 np203/205
52" fornt springs
56 or 63" rear springs
stretch the wheelbase out to around 110"-112"
40ish tires on Humvee beadlocks
Steel trail bed of some sort
05 1500 Crew Cab
79 K10 Scottsdale
71 K10/Custom
85 K30 CrewCab
72 Camaro
konajoe is offline   Reply With Quote
Old 10-18-2015, 09:23 PM   #2
konajoe
konajoe's Avatar
Re: 71 Trazer 4x4 Project
Spent a few hours today cleaning the truck out, removing the rear bumper and bed.
Unfortunately the back half of the chassis is not as good as i initially thought it was. It's pretty thin in a few spots. Thankfully from the back of the cab forward its great shape so the plan is to cut it off and build a new rear section.
05 1500 Crew Cab
79 K10 Scottsdale
71 K10/Custom
85 K30 CrewCab
72 Camaro
Old 10-19-2015, 01:24 AM   #3
swamp rat
swamp rat's Avatar
Maybe its my work computer but i got the dredded red X's instead of pictures. Good luck with the build!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-01-2015, 08:34 AM   #4
RANDY COX
RANDY COX's Avatar
Judging from the drum brakes in the front and the faded red lockouts I'd say it's about a 70, my ole 4x4 Burb was the same way ,anywho saound like you have a plan can't wait to see the build...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 11-01-2015, 09:21 AM   #5
raggedjim
raggedjim's Avatar
I like it, I remember seeing one in Great Lakes during my navy daze.
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 11-15-2015, 10:40 AM   #6
konajoe
konajoe's Avatar
Yeah i think your correct... the cab may be from a 71 C10 but the chassis & running gear is from a 69 or 70 K5 Blazer
I was able to spend a few a hours yesterday working on the truck.
The cab floor isn't too bad for a 44 year old New England truck.
Only bad spot on the floor besides the rockers and cab corners.
Pulled off the nose and found the cowl is going to need a some TLC. Unfortunately the PO left the truck sitting under a bunch of trees and the cowl was packed full of leaves and junk.
Thankfully the hinge pillars are still decent.
The next step is to pull the cab off the chassis
05 1500 Crew Cab
79 K10 Scottsdale
71 K10/Custom
85 K30 CrewCab
72 Camaro
