10-18-2015, 01:13 PM | #1 |
1951 3100 by Tre 5 Customs
We just received another one of these projects last Thursday. It sat at another shop for 3 months, untouched! He brought it to us on Thursday, we started on it Monday and here it is as of the end of the week. I won't get much done on it till after SEMA, but we wanted to get it torn down and get parts ordered. Speaking of ordering parts.. here's the short list of goodies going on this build:
Lots of new parts from LMC Truck, Roadster Shop REVO chassis, Turnkey Engine Supply 500hp LS3 and 4L65E trans, Baer 6 piston brakes, 20" and 22" Intro Designs wheels, Ridetech coil over shocks, and many more. I have a good budget for this truck, but a very tight timeline. It is supposed to be done by the end of January. I did not promise that to my customer, but I will do all I can to meet it. Here's some photos.
Follow me on facebook and Instagram. Tre 5 Customs My '49 http://67-72chevytrucks.com/vboard/s...d.php?t=673809 Customer build: 67 Blazer Roadster http://67-72chevytrucks.com/vboard/s...d.php?t=443105 Customer build 1980 C10 http://67-72chevytrucks.com/vboard/s...49#post7210949 |
10-18-2015, 01:15 PM | #2 |
Re: 1951 3100 by Tre 5 Customs
This is my customers Dad's truck so he wanted to keep everything we won't be using. SO we decided to store it at the local storage place till he comes back with a two car trailer to take it all home to NM.
10-18-2015, 01:18 PM | #3 |
10-18-2015, 01:21 PM | #4 |
The previous modifications were made by his Dad, back in the 70's, which makes them easy to remove, lol. Drill out some rivets and cut off the brass. The chassis is about 2 months out, so we will start with the rust repair and body work.
10-18-2015, 04:51 PM | #5 |
Exciting project...always nice to have a good budget! Interested to see the Revo from RS.
Was the other shop too busy or ...? |
10-18-2015, 05:04 PM | #6 | |
Posted via Mobile Device |
10-18-2015, 08:46 PM | #7 |
A320 Pilot/USAF Retired
Sounds like a great project!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
10-19-2015, 03:36 PM | #8 |
Been watching on Instagram....I'll watch here too. Sub'd
10-19-2015, 04:12 PM | #9 |
I'll follow along, pretty tight timeline!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
10-19-2015, 05:23 PM | #10 |
Ready to see this one...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
10-20-2015, 02:34 AM | #11 |
looks like a good start!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
10-20-2015, 04:31 PM | #12 |
gonna be sick
big_moss bagged 51 3100 build |
11-24-2015, 10:41 PM | #13 |
Rust repair under way.
Bye bye gas filler Fixing rust on the doors We paint the insides before the final piece goes on to prevent future rust
11-24-2015, 10:44 PM | #14 |
01-24-2016, 01:17 PM | #15 |
So, I'm way behind on updating this thread....
Here goes: The chassis from Roadster Shop showed up We got right to work installing the RideTech coilovers and Baer Brakes, before mounting up the Intro Wheels. We were spending time getting the door gaps dialed in before it goes on the chassis Then the cab was mounted up to the new chassis so we could build a new firewall
01-24-2016, 01:20 PM | #16 |
01-24-2016, 01:26 PM | #17 |
The intake tube is one for a 2000 tahoe. We cut a hole in the inner fender and located the K&N filter in the wheel well.
All the other sheet metal parts were also mocked up so we could finalize everything before paint and powdercoat. The exhaust needed to be tacked in place temporally so we could get the body back to the painter as soon as possible. You can just barely see the exhaust tips peaking out below the rear bumper. Bedside tubs needed to be made for clearance of the 22x10 wheels. The bed floor was also raised at this point
01-24-2016, 01:28 PM | #18 |
01-24-2016, 01:30 PM | #19 |
Last thing we did before the truck headed back to the paint shop was mount all the under dash stuff. A/C, ECUs, Fuse blocks, relays, Dakota Digital controller, gas pedal, etc. were all mounted
Then it was off to paint...
01-24-2016, 01:33 PM | #20 |
For paint, we decided to go with green. Originally the truck was going to be a black and silver two tone, but since this is for his dad and the truck was originally green I talked him into respraying the truck green. The color is a custom tri coat color from Fashion Paint.
I also made a matching tailgate skin that matches the bead rolled firewall
01-24-2016, 01:39 PM | #21 |
After all the gaps were dialed in with the cab bolted to the chassis, the truck was blown back apart. While the body panels are getting final blocking and paint, we got busy finishing up the chassis.
The exhaust was built out of 3" stainless steel tubing. We planned out running wires and fuel lines through the frame rails You'll also notice we built a gas tank to fit between the Black Widow mufflers. Then the chassis was blown apart for powder coat
01-24-2016, 01:43 PM | #22 |
The parts were dropped off at 10am Monday morning, and I got them back Wednesday at noon. Pretty good service I'd say.
I decided to go with a black/ copper vein on the chassis and a high gloss black on the suspension parts. I got right to work assembling the chassis components.
01-24-2016, 01:44 PM | #23 |
While all that was happening, IKandy Paintworks was busy laying down the color after a few more prime and block sessions.
01-24-2016, 01:46 PM | #24 |
01-24-2016, 01:49 PM | #25 |
Steve from Elevated Design came down to the shop to wrap the dash and area around the back window in material that was sent with the seats from TMI Products.
Speaking of seats, here they are. I'll have to build custom mounts for them and there will be a center console flowing from under the dash, between the seats, and all the way to the rear wall.
