10-18-2015, 03:20 PM | #1 |
AC Vents
Need some help. I purchased new AC vents for the dash. Is there another part that keeps the AC vent ball from falling out the back? I have the outlet bezels but it looks like something should be on the back keeping the ball from falling out. Any takers?
10-18-2015, 03:31 PM | #2 |
Old member
Re: AC Vents
Once you install the dash part you put the ball in then there is a strip of foam that should go in it also to make the ball stay as you point it and not let it roll around inside the housing.
10-18-2015, 04:24 PM | #3 |
Re: AC Vents
Its actually a felt strip. I assume foam would tend to stick, or grab too much.
10-18-2015, 05:50 PM | #4 |
Re: AC Vents
I think the OP is referring to the piece that connects to the vent hose.
LMC calls it the "air outlet adapter" They look something like this
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
10-19-2015, 12:15 AM | #5 |
Re: AC Vents
Thanks bigdav160. I knew there was something else that connected to the hose.
10-19-2015, 05:49 PM | #6 |
Old member
Re: AC Vents
Glad you figured it out. I was going by your original post and thought you wanted to keep the ball inside the dash vent. Not connecting the hose.
10-20-2015, 01:03 AM | #7 |
Re: AC Vents
No worries Andy. I have the right parts on order. Thanks.
10-20-2015, 08:58 AM | #8 |
Old member
Re: AC Vents
Good deal!
LMC has the best pictures of anyone. May not always be best parts are price but you can't beat their pictures!
10-22-2015, 05:23 PM | #9 |
Re: AC Vents
Yes, I agree. They have better pictures for sure.
12-11-2021, 06:38 PM | #10 |
Re: AC Vents
Got a question. What is the order of the parts going together? When I took off the hose adapter everything fell out and I don't know where to attach the felt strip.
I believe the order is: - Dash A/C housing (Back facing up) - Felt strip installed to the bottom - A/C ball vent - Install another felt strip to the bottom where the adapter changes sizes - Assemble the hose adapter and the a/c housing into one unit Is this right?
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
