10-20-2015, 12:34 PM | #1 |
wood bed header panel
Question pertaining to the header panel of the box. Its my understanding that a wood bed sits on top of the header panel flange. Correct?
In my case my truck is some sort of monster and its been quite the mess... Took well over 8 hours to get the rotten wood out of the way for my new boards. Question is (and I already have the wood) do I need to replace the header panel with the correct part for the wood to fit correctly or can I run it the same way the PO ran the wood. Which is under the flange all the way around the bed. Near as I can tell I have the correct cross braces and the correct tailgate panel for wood just incorrect header panel. Cut my boards using the old cutouts as a guide of sorts was left with a few sections of ply wood after the tubs were removed. Got most of the wood out still have a few sections left to fight every nut in the bed was rusted to the bolt. I can't even begin to explain this night mare. PO had a rotten bed and instead of replacing the rotted wood he just put another layer of 3/4 ply right on top which has left me with a bit of rust issue. was left with some fire starter after it was all said and done!!!! And yes that is a porterbuilt c-notch in the foreground of this pic build thread to come soon.
-Blake 1972 Big Block SWB http://s165.photobucket.com/user/bla...how/1972%20C10 1969 LS3 Nova http://s165.photobucket.com/user/bla...Nova%20Uploads |
10-20-2015, 01:56 PM | #2 |
Re: wood bed header panel
correct on the first question. i would find a wood panel otherwise the front of the wood won't be supported. i believe someone makes a conversion bracket but i forget if it's for converting FROM or TO wood... or you could probably make one easy enough that spans underneath. it might look a bit funny at the top where the trim pieces end.
i think mostwood beds are inthe condition you described. definitely a lot of work!
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
10-20-2015, 04:08 PM | #3 | |
Thanks!
