10-23-2015, 12:38 AM | #1 |
Always on the hunt...
FS: BBC/TH400 No Hole High Hump Tunnel Covers
All of these pictured no hole high hump bolt in tunnel covers were removed from 2wd BBC/Th400 automatic trans trucks, the two covers pictured on the left are $115. plus ship, the one pictured on the right is $150. plus ship and has the factory stamped hole floor ring section cut out & removed complete from the trucks floor pan. Some guys like purchasing and using this method as they can then also use the OE spot welded nut strips and bolts while doing the conversion. If interested in one, let me know your ship to Zip and confirm if its going to a residential or business address and I will get you a shipping quote. Thanks, Mel.
10-23-2015, 12:41 AM | #2 |
Re: FS: BBC/TH400 No Hole High Hump Tunnel Covers
This one was removed from a 68 BBC/TH400 truck...
10-23-2015, 06:18 AM | #3 |
Interested in the one on the far right zip is 06010 residence
10-24-2015, 04:59 AM | #4 |
Will give you two different options on shipping the high tunnel w/floor pan section cut out, while still being 16.5 lbs. the second option saves a bit on shipping due to the smaller box size. Let me know, Mel.
Option #1 ship as pictured complete and still bolted together to Bristol, CT. 06010 / $49.61 sent via Fedex 5 business day home delivery. Option #2 unbolt tunnel from floor pan ring and cut floor pan into four sections (between nut strips) pack/send all pieces to Bristol, CT. 06010 / $36.20 sent via Fedex 5 business day home delivery. |
10-24-2015, 09:45 AM | #5 |
How about the one in the middle to commercial address to 93611?
10-24-2015, 10:50 AM | #6 |
12-10-2015, 10:46 AM | #7 |
I would like the one on the far left in the picture top left with the three shown.
71107 it is a business or commercial address. Thanks, Pat |
12-10-2015, 06:39 PM | #8 |
Hi Pat, shipping cost on the far left high hump to Shreveport, LA. 71107 (Business) is $27.63 sent via Fedex ground, total transit time would be 4 business days once shipped out. Let me know, Mel.
12-11-2015, 10:27 AM | #9 |
12-11-2015, 10:35 AM | #10 |
Payment sent
12-11-2015, 07:31 PM | #11 |
Still have one of these left? I'll take you one if so pm me total shipped to 41042 business address.
12-11-2015, 07:46 PM | #12 |
The high hump tunnel cover pictured on the left has been sold/paid for, the other two are available yet. I can get you a shipping quote to Business Zip 41042, but which of the two are you interested in? Shipping is quite a bit more on the complete cover (pictured right) and floor ring setup due to the size and 8 pound weight differences, if wanting this complete one also check out above post #4 for yet another option to cut down the shipping. Let me know, Mel.
12-11-2015, 07:59 PM | #13 |
I don't need the extra part.
12-11-2015, 08:46 PM | #14 |
Shipping cost on the middle pictured high hump to Florence, KY. 41042 (Business) is $31.70 sent via Fedex ground, total transit time would be 4 business days from our door to yours. If you decide that you want it, let me know your preferred method of payment and I will handle things on my end. Thanks, Mel.
12-11-2015, 11:48 PM | #15 |
12-12-2015, 12:42 AM | #16 |
I'll take it, sending payment
12-14-2015, 11:07 PM | #17 |
01-03-2016, 12:06 AM | #18 |
Do you still have 1 available?
08-07-2016, 09:17 PM | #19 |
Hump on the right still available?
08-07-2016, 09:51 PM | #20 |
Yes, the green one from the 68 BBC/TH400 truck is available yet, this one still has part of the floor pan attached so it kicks the shipping cost up quite a bit due too now using dimensional weight in the quote. I could probably remove/unbolt the floor pan ring and cut/package the ring in a few sections (not harming the nut plates) along with the cover for around the same cost as listed above on the others. Let me know your thoughts along with a shipping Zip confirming business or residential and I can get you an exact cost via Fedex. Mel
08-07-2016, 10:30 PM | #21 |
I'll get in line for the green one if Eagle doesn't do it. Cost to ship to 35613 residential? I'd probably go with the cut option. Just the three nut plate sections, bolts, and tunnel. Don't need what's left after that. Thanks.
08-07-2016, 10:49 PM | #22 |
Out of curiousity, how are the nut plates attached? Are they spot welded, tack welded on whole edge, tacked in a few spots, glued, etc? Thanks.
08-08-2016, 10:44 AM | #23 |
I actually already have a couple of high hump covers, I was mainly interested in this one for the section of the cab floor that is with it.
Mel/General23cmp, maybe we could separate the two pieces if General just needs the hump? |
08-08-2016, 10:58 AM | #24 |
That's ok Eagle, it's yours if you want it. I was looking for the whole package including the nut plates too. No big deal.
I'll take it if you decide to not to buy. Last edited by General23cmp; 08-08-2016 at 09:04 PM. |
08-08-2016, 08:49 PM | #25 |
You take it man, I've got others.
