Old 10-23-2015, 05:51 PM   #1
83 Scottsdale
Should I add an EGR?
I have a 1983 K10. The original engine was a 305 but it was swapped to a crate 350 before I bought it. I was diagnosing a problem my truck had, and I read somewhere that the EGR could be plugged which was causing the problem. So I looked at my engine and I found that I don't have an EGR. There is a plate bolted on where the EGR should be and the manifold vacuum line is plugged off. So I'm thinking that when they swapped engines, they didn't put the EGR on. I did more research on EGR's and apparently they add 1-2 mpg. My question is if I should buy and EGR and install it, or just leave it? I think they run about $50-70 so would it be worth it or not? Also, would it mess with my timing? Any help is appreciated!!!
Thanks.
83 Scottsdale is offline   Reply With Quote
Old 10-23-2015, 06:07 PM   #2
68c10owner
68c10owner's Avatar
Re: Should I add an EGR?
I took mine off and the truck runs better. Cant comment on the mileage but if you do add it you will need more than just the EGR valve. You will need the EGR solenoid and the valve that goes into the air cleaner. If you dont need to smog your truck leave it off.
Anthony
68c10owner is offline   Reply With Quote
Old 10-23-2015, 06:19 PM   #3
83 Scottsdale
Ok, thanks. I'm going to assume that my truck doesn't already have those either. I cant find any pictures or diagrams of it for my truck, so I don't know where everything plugs in at. Do you have any pictures of yours or know where I could find one?
Thanks.
Old 10-24-2015, 05:10 PM   #4
Dead Parrot
It may have had one originally. But since the motor was swapped and it sounds like the PO removed most of the emissions, probably best to proceed as though it won't have emissions. Adding them back piecemeal is a good way to add to your frustration level.
What's the problem you are trying to fix?
Dead Parrot is offline   Reply With Quote
Old 10-25-2015, 06:47 PM   #5
Tom
driving is in my blood
Tom's Avatar
Who said EGR adds mileage? Think of it this way: how does adding spent exhaust with no energy to put into the combustion cycle for motivating the truck down the road add mileage? Its purely for emmisions.
EGR, or the lack of, is not causing your problems.
Old 10-27-2015, 12:32 AM   #6
83 Scottsdale
Well, my problem has been dubbed "the morning miss". Early in the morning when I first drive it, I go up this small hill at low rpms and the engine will miss. I've read that it could be the timing, it could be moisture in the distributer, it could be a pinhole in a spark plug wire, or it could be the EGR crapping out. That's what got me looking into the EGR stuff. It seemed to be the most common problem. I don't know what the issue on my truck is but I find that if I just warm up the engine a bit longer then it doesn't happen. So I'll just stick with warming up my engine until I can figure it out for sure. And to the one saying it doesn't increase mph, I read that because it recirculates the exhaust, your engine uses less fuel, and the oxygen percentage is lower. This all causes the timing to be a bit more efficient. That's why I wanted to add a EGR. I read stories where people bought an EGR delete kit and their milage went down. I guess it just depends on the vehicle it's in.
Old 10-27-2015, 08:07 AM   #7
kody1234
it may just need a tune up.
kody1234 is offline   Reply With Quote
Old 10-27-2015, 09:03 AM   #8
hatzie
Moderator
hatzie's Avatar
Is the EGR valve still on the intake or did the PO install a proper block off plate?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-27-2015, 11:10 AM   #9
83 Scottsdale
There is a block off plate where the EGR should be. And I don't see the EGR solinoid. But I do see the vacuum tube from the manifold was just cut and had a screw blocking off the line.
Old 10-27-2015, 12:45 PM   #10
68c10owner
68c10owner's Avatar
My 85 has this same problem. it misfires until it warms up. Probably a EGR solenoid which I believe to be the same issue as mine. I removed my EGR and installed a plate and it runs better but still have that misfire in the morning. After about 30 seconds it goes away. But if your truck doesnt even have a EGR solenoid then I dont see how that can be the problem.
Anthony
Old 10-27-2015, 02:32 PM   #11
83 Scottsdale
Yeah, I was diagnosing the problem and I went to check my EGR and then realized that I don't have one. So then I was wondering if I should have one or not. So that's why I was asking you guys if I should install one or not. It looks like it will cost too much anyways. Not worth it too install one.
egr, egr valve, no egr, should i add an egr?
