Old 10-23-2015, 07:11 PM   #1
dzbowtie
dzbowtie's Avatar
gas cap question
hey guys,
this may be a very simple question, but i have a non vented tank, which i have a vented cap. the question is, is this vented cap supposed to be loose, with a slight wobble? it is a locking cap. if i place it on the neck with the first 2 pronges, til it clicks, it is obviously loose enought to vent. but, then i can turn it about a 1/4 turn, like a radiator cap, till it tightens, but then i notice some pressure building up in the tank, and some slight fuel coming from the key hole. should i just leave the cap loose? thanks for your input.
dzbowtie is offline   Reply With Quote
Old 10-23-2015, 10:31 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: gas cap question
If it's a regular locking cap, line the tangs up with the gas fill and press down.
It will feel spongy but that's normal...no turning needed.
As for leaking & pressure building up..here's how they work.
BTW.. these things can go bad. When it seems Like a fuel related problem, one of the first
things to try is loosen the cap.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
