Old 10-24-2015, 02:09 PM   #1
Gromit
DIY Gaskets - Japan Scissor Master
I've been doing it wrong! (making DIY gaskets)
Part of the youtube video linked below (starting at minute 14:30 and ending at about 19:00) is of Hayashiya Shoraku a Japanese Scissor Master
He cuts these intricate shapes very accurately partly by using just the very tips of the scissors; and by holding the scissors relatively in the same plane and moving the paper instead of the scissors..
I tried his technique on a sheet of that 1/8" thick hobby-type foam to make a new seal for my backup taillight lens yesterday. It came out much better than my previous sad efforts at cutting gaskets; so it does work.
For perfectly round holes a set of hollow punches is still useful.
https://www.youtube.com/watch?v=4E7ZYmBYLUg
Gromit is offline   Reply With Quote
Old 10-24-2015, 02:23 PM   #2
leftybass209
leftybass209's Avatar
Re: DIY Gaskets - Japan Scissor Master
Yes it works, and I've done it several times. Mostly with gaskets that I purchased that were a weird color that didn't match what I was after, Ie: white or grey lens gaskets. I've sealed a lawnmower engine with gaskets made from a manila folder, and it never leaked a drop.
The only issue is the products used HAVE to withstand the torque specifications set by the manufacturer, and not break down due to elements or oils.
leftybass209 is offline   Reply With Quote
Old 10-24-2015, 07:16 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Have done similar gasket cutting myself.
I used to restore late 50's through late 70's Stihl, McCulloch, and Homelite chainsaws. Not many gaskets out there still available for those old magnesium beasts. So I made a lot of my own stuff with scissors and hole punches. Electrician/lineman scissors work great too, as they are short, stubby and sharp as a razor blade.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-24-2015, 08:49 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
I've been using small snap blade utility knives to make gaskets.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
