Old 10-24-2015, 03:42 PM   #1
GTSideSwipe
Transmission Swap Question
Hi. So I have a question regarding swapping out my turbo 400 on my C20. It's the original 400 with a two piece drive shaft. I am wondering if there are any overdrive transmissions that would work so I wouldn't have to do anything like cutting the drive shaft.
GTSideSwipe is offline   Reply With Quote
Old 10-24-2015, 05:03 PM   #2
EARNHARDT#3
EARNHARDT#3's Avatar
Re: Transmission Swap Question
What length tail shaft do you have? If it's 4" then the 2004r and 700r4 are pretty close.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 10-24-2015, 05:27 PM   #3
GTSideSwipe
I'm not sure which tail I have but I will be able to check on Monday. I have a 700R4 tranny that is laying around in my garage so I was thinking about swapping in to lower the rpm a bit especially at freeway speeds but just am not sure.
Thanks for the info.
Old 10-24-2015, 05:32 PM   #4
57larry
is the drive shaft yoke the same on a 400 & 700R4?
57larry is offline   Reply With Quote
Old 10-24-2015, 05:39 PM   #5
GTSideSwipe
No. You will have to use a different yoke. It looks like the 700R4 4L60E TH350 are the same but the 400 is different.
Old 10-24-2015, 06:01 PM   #6
hugger6933
If you use you3/4 ton like a 3/4 ton, you want to look into the 4L80E trans but here is the downside, it has to have its own controller. Those can run you in the $300 to up on the controller and each do nothing without it. I 4L80E is built stronger from the factory than a 700R4 that has been Modded to some small degree but can take plenty abuse.
So if hauling or towing get the 4L80E. Lots of drive line places can do a drive shaft using what you have for less than a hundred bucks, Jim
hugger6933 is offline   Reply With Quote
Old 10-24-2015, 06:18 PM   #7
Clavo106
thank for sharing that picture. makes mock ups more easier.
Clavo106 is offline   Reply With Quote
Old 10-24-2015, 06:46 PM   #8
Jrainman
Jrainman's Avatar
I agree here with Hugger , also with the 700R4 you will have to add kick down linkage , the TH400 is a strong trans that's why its in your truck and has been for over 40 + years
if its just fuel economy your after have you thought about changing your diff gear ratio . you could gain a couple MPG and even more depending on your drop in ratio.
Jrainman is offline   Reply With Quote
