6.0 into a 1961
I have looked over and over but cannot find any info on swapping a 2001 LQ4 into a 1961 Apache.
I cannot find a motor mount kit, I have no mounts right now. What do you guys suggest? I also cannot find any info about the crossmember, does it need to be swapped? If so to what? |
meowMEOWmeowMEOW
Re: 6.0 into a 1961
Your swap shouldn't be any different than the other 60-62 guys, and it will still have plenty of shared components with the 63-66 swaps, which there are many of. You might be able to get more ideas, faster, by taking a look at what the other 60-62's have put together. The "what ya got" thread up top is also helpful for general ideas, and to point you in the direction of members with similar swaps.
IS the 61 stock right now? Drum brakes, X-frame(iirc) etc So many of these trucks have had 30+ years of changes, so its not uncommon to find modified frames, swapped crossmembers and brakes (especially this!) and other changes. Motor mount suggestions will be based partially on this^. Its kinda like throwing darts at a parts list until we know exactly what your working with (and what you want to do with it). Just on mounts for example, people have used everything from swap adapter plates, homemade mounts, aftermarket perches/stands, and entire custom xmembers. In many cases, all of the above can be made to work. So, there I made things 20x more complicated.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#3 | |
Re: 6.0 into a 1961
I talked to CPP yesterday and ordered 6372MP-SM BLACK SHEET METAL SMALL BLOCK MOTOR PERCH (PR) 1963-72 CHEVY TRUCK W/ SMALL BLOCK V8 LS1-KULAC-P ADJUSTABLE LS ENGINE ADAPTER BRACKETS KIT WITH POLY-PLUS PADS (WORKS WITH LOW AC) We are going to weld the mounts in place I also ordered the Thorley headers! HEY I LIVE IN BREW CITY.................................LOL |
Re: 6.0 into a 1961
One thing I am wondering, and I know I will not know for sure until I do the mock up is...will I need to change oil pans?
![]() Join Date: Apr 2005
Re: 6.0 into a 1961
Yes
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: 6.0 into a 1961
