10-26-2015, 07:37 PM | #1 |
FITech Experiences ?
Hey, I was doing some research and came across a newer bolt on FI product. The company is called FITech. From the research I've done so far it seems they do some OE work and this is their entry in to aftermarket.
Besides some interesting features on the unit itself they offer a "fuel command center" which is essentially a separate small fuel feeder tank and pump that feeds the FI unit from supply by your regular fuel pump so it makes it a fairly easy install. Limited reviews as I believe they have only been shipping since the spring but I haven't found any real negatives yet. Oh yeah, very attractive price point. Below is a link to their website and then a review I found with some Dyno time comparison. If you google you can find some more reviews and some youtube videos. Anyone running one of these or know of those who are? I'm considering giving one a try but looking for some more input. Product: http://fitechefi.com/default.asp.pg-Products Review with Dyno comparison: http://forums.maxperformanceinc.com/...ghlight=Fitech
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
10-26-2015, 07:52 PM | #2 |
Re: FITech Experiences ?
I brought this up About a week back
Read some good reviews on the corvette forum I'm likely to purchase one after the first of the year got too many balls in the air right now Also there's a write up on the install in the c10 builders magazine I picked up the other day |
12-05-2015, 09:58 AM | #3 |
I'm curious on how big that command center deal is and if it will be worth it or just run a return system...
12-05-2015, 01:40 PM | #4 | |
Never Ending Projects
http://fitechefi.com/virtualoffice_files/40003.PDF I have heard from folks who are running them at the local Auto-X that they are working great. I am planning to visit them on my holiday break. Very seriously looking to do this for my panel.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
12-05-2015, 01:46 PM | #5 |
Seems to be a good product. I suspect like anything else that once its proven to work well and become popular the price will go up like the rest of the aftermarket units. I`d love to get one myself but not in the funds right now.
Anthony |
12-05-2015, 04:05 PM | #6 |
Rodsgreenc10 is putting one on his now. http://67-72chevytrucks.com/vboard/s...605736&page=16
12-27-2015, 09:05 PM | #7 |
But Found Her 25yrs Later!
Just stumbled across this while reading up on TBI.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
12-27-2015, 11:09 PM | #8 |
I posted this in another post. I have this new system on pre order. A buddy is running the 600 HP version for the last year with no problems.
So I was talking to FiTech today and got the scoop on a new system that should be out in the next 30-45 days. This will be their Go Street version, which will be selling at $795!!! What they are doing is using injectors to support up to 400 HP, no timing control (which many of their customers are not using with their higher series units), no boost or nitrous control. It still has the self learning, wide band O2 sensor and much of the same functions that the 600HP unit has. This is going to put a very affordable EFI system in reach to so many folks who thought it would be too expensive. Heck, add their Fuel Command center and you won't need to do any fuel tank mods. I am hoping to get one of the first of the Go Street units! Video they just released - https://youtu.be/LK-qLlGotUU
12-28-2015, 10:04 AM | #9 |
I also posted in the other thread.
Just curious if Computer Controlled Spark has any advantage. Otherwise, I'm waiting for the $795 one.
12-28-2015, 10:46 AM | #10 |
Lostmy65, good point, would an hei distributor be what they are saying as a 'special distributor'? How does one go and pre-order that model? Part number?
12-28-2015, 11:07 AM | #11 |
Here's an interesting article :
http://www.crankshaftcoalition.com/w...EI_distributor . And a related thread : http://www.chevelles.com/forums/arch.../t-330999.html
12-28-2015, 12:59 PM | #12 | |
Has no advantage over running hooked to HEI. If you have the HEI dialed in you will see no advantage over the FiTech controlling timing. Either way you will have to Curve your HEI and set timing. And if you let FiTech control timing you will have to phase your dizzy. So you have to get it setup correctly to begin with either way. I post all of this on my build thread already just have to read through the posts. But figure I would post it again. |
12-28-2015, 05:00 PM | #13 |
Will the Fitech work with a semi rough cam?
I think my engine only pulls about 10# vacuum at idle.
12-28-2015, 05:02 PM | #14 |
12-28-2015, 05:06 PM | #15 |
Thanks.
I'm about as anxious for the pre-order on this Go Street FiTech as the release of the coolest new Smartphone.
12-28-2015, 05:16 PM | #16 |
12-28-2015, 05:17 PM | #17 |
Yep, going through your thread now.
12-28-2015, 06:41 PM | #18 |
So I see the advantage of using the FCC, but for $395 is it worth it, or would it be just as expensive to install a tank that uses an in tank fuel pump?
12-28-2015, 06:58 PM | #19 |
Go back a few pages on my trad and you will see what I have in the fuel setup. FCC is cheaper by a long shot. But I went intank setup for a clean install look.
12-28-2015, 07:02 PM | #20 |
Yep, I posted too soon.
I just came across that post in your thread. Your thread freakin rocks with info on the install. I see another joined this forum just because of your thread. He probably googled Fitech and your thread was one of the top hits.
12-28-2015, 07:05 PM | #21 |
Haha. Thanks Man. I try to be as detailed as possible so people know what they are getting into. I can't stand when people post half ass info and leave people hanging. It helps out everyone when you give all the details so that is what I try and do.
12-28-2015, 07:16 PM | #22 |
12-28-2015, 07:17 PM | #23 |
Hold On!
Is the Go Street out already? And am I reading it correctly, it also includes Spark Control? https://www.jegs.com/webapp/wcs/stor...ey=http:Logoff
12-28-2015, 07:19 PM | #24 |
12-28-2015, 07:20 PM | #25 | |
And to answer your question yes it is out lol. |
